Issue with setting multiple values in a single macro using "OR" with Set Macros in RapidMiner
I am currently facing an issue with setting multiple values in a single macro using "OR" with Set Macros in RapidMiner.
I have tried using the following syntax to add multiple values to a macro:
{value1|value2|value3}
also few other syntax with and without the curly braces also
I would greatly appreciate it if anyone could share any insights or solutions regarding this issue.
Mo_Abdolrahim @MarcoBarradas @MarcoBarradas
1 - 9 of
91
Hi Jonas,
I'll take an example, let's say to specify a Macro for a column named "Fruits", the purpose of the Macro is to select the values "apple", "banana", and "orange" from this column using the "OR" operator. However, I am facing difficulty in defining multiple values for a single macro.
Regards,
M
Something like this?
<?xml version="1.0" encoding="UTF-8"?><process version="10.1.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="10.1.002" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="10.1.002" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="34"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="Id,Fruits 1,apple 2,orange 3,banana 4,pineapple 5,tomato 6,pear 7,apple"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="true"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="set_macro" compatibility="10.1.002" expanded="true" height="82" name="Set Macro" width="90" x="246" y="34"> <parameter key="macro" value="fruits"/> <parameter key="value" value="apple|banana|orange"/> </operator> <operator activated="true" class="filter_examples" compatibility="10.1.002" expanded="true" height="103" name="Filter Examples" width="90" x="447" y="34"> <parameter key="parameter_expression" value="matches([Fruits], %{fruits})"/> <parameter key="condition_class" value="expression"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"/> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="true"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
Can you share an example process of what you want to achieve?
At least to me it's not clear where the values are coming from.
Greetings,
Jonas
