🎉Community Raffle - Win $25
Join and Win
Buggy UI
User: "PDavid"
New Altair Community Member
Updated by Jocelyn
Hello,
I'm trying to learn with RapidMiner but after few clicks in rapid miner it always starts to "rewrite picture" or I don't even know how to describe the problem  :D
I'll provide picture in attachment.
I have quite powerful PC so it can't be that problem. Specs:
AMD Ryzen 7600x
AMD Radeon 6700XT 12GB    (active)
Kingston Fury 16GB DDR5
all drivers are up-to-date, I have already check that.
I use plugin/extension for finance and economics
Other programms don't have this issue.
And if we solve this problem, I wanna ask if I can utilize my GPU as an accelerator? I know it is powerful when you are training ML script using Python, but I can find GPU accelator in RapidMiner
Thank you for your time. :)
1 - 3 of 31
    User: "jwpfau"
    Altair Employee
    Accepted Answer
    Hi,
    this can be caused by MSI Afterburner or similar tools that hook into the D3D rendering pipeline,
    Can you try to add J2D_D3D  false to your system environment variables and restart RapidMiner Studio?
    Regarding the other question, the deep learning extension currently only suports cuda, which is NVIDIA exclusive.
    Greetings,
    Jonas
    User: "PDavid"
    OP
    I cant find a way to do that. Could please help me? And won't this affect other applications somehow?
    Don't you know if there is plan to support AMD GPUs? :)
    Thank you for your help.
    User: "jwpfau"
    Altair Employee
    Hi,
    try to search for "Variabile de mediu" in your windows start menu, and yes It would also affect other java applications.
    You could also try to enable the "HTML5 Safe Mode" in the settings to see if this already helps.
    Greetings,
    Jonas
