🎉Community Raffle - Win $25
Join and Win
Topic Modeling for PDF files
User: "Karissa"
New Altair Community Member
Updated by Jocelyn
Hello everyone,
I want to read several PDF files (business reports) and analyze them. Until now I use the operator Read Douments, because I haven't found a better operator yet.
I want to do a topic modeling on the files to find out relevant topics. A pre-processing is done by the operators Tokenize, Transform Cases, Filter Stopwords, Filter Tokens by Length and Stem. For this I have found the two operators: Extract Topics from Documents (LDA) and Extract Topics from Data (LDA). Unfortunately both do not work properly.
Extract Topics from Documents( LDA) needs a collection as input and I don't know how to get it.
And Extract Topics from Data (LDA) needs a text attribute and again I don't know how to get it.
Accordingly, I have these two questions:
1) Is there an operator I can use to read in multiple PDF files?
2) What is the best operator for Topic Modeling and how do I implement it?
I have created the process below, it runs, but I only get null values as results. Does anyone have a tip for me?
Many thanks for the help
1 - 4 of 41
    Hey,
    I think what you want to do is use Loop Files, to loop over your files and then use Read document inside. What you will receive is a collection of documents, which you process as needed.
    Cheers,
    Martin
    User: "Karissa"
    OP
    Thank you @MartinLiebig . The Loop Files Operator worked.
    The process runs through, but all results are zero/null. What could be the reason for this?
    Many thanks
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hi,
    likely the texts are for some reasons empty?
    BR,
    Martin
    User: "Karissa"
    OP
    I have changed the process and now I get a result. Many thanks.
