🎉Community Raffle - Win $25
Join and Win
How to I sort out various unstandardised data from a single cell ?
User: "ETMZ"
New Altair Community Member
Updated by Jocelyn
Hello everyone,
For context, I'm trying to find out which marketing medium is the most effective to be used by Starbucks.
Attached is the dataset used and the column pertaining to my part is question 19.
As you can see, the data are retrieved from survey forms, as such, the format of their answer varies (e.g. some people only choose 'social media' as how they hear about promotions whereas some chose multiple methods (e.g. Starbucks Website/Apps;Social Media;Through friends and word of mouth). So my question is, is there anyway that i can sort out those with multiple answers so i can accurately count which is the most favourable medium to be used?
Thank you !
1 - 9 of 91
    User: "Telcontar120"
    You can easily separate out the separate items using the Split operator.  It looks like the semicolon is your split pattern.  Then you can count the distinct values using Aggregate.  The sample tutorial processes in the software should show you how to set it up.
    User: "ETMZ"
    OP
    Updated by ETMZ
    @Telcontar120 thank you so much for responding !!! However, i do not understand the ratio part. How do i split it using semicolons?
    The Split operator has a parameter called "split patten" where you specify the character(s) that should be used to accomplish the split. Were you able to open the tutorial process under the help menu for the Split operator as I suggested? That should make it clear.
    User: "ETMZ"
    OP
    @Telcontar120 are you referring to this?
    Accepted Answer
    You need the Split operator, not Split Data. Use the operator search and it will come up.
    User: "ETMZ"
    OP
    @Telcontar120 please excuse my stupidity ahhhaa
    anyway i have managed to split the data however the marketing method has now become as below, may i know what do you suggest to tidy things up so that i can count the value using aggregate
    I think this very much depends on exactly how you want to represent the data, given that any individual example can have several marketing methods. You can of course simply aggregate and count examples for all the values of your first 3 marketing methods, for example. But you may want to do something more complicated, in which case you probably are going to want to look at some of the text processing operators which would allow you to use the original data (before you split it) and tokenize it and then count total occurrences of specific tokens of interest. This is something that would probably be outside the scope of complexity that someone would be able to offer guidance on a forum like this.
    User: "hainaha4"
    Updated by hainaha4
    hello,
    i am new here from india, here to share some thoughts with you all  panoramacharter.ltd
     19216811.bid
