Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
Filter
TuanNguyen
I couldnot connect a operator ("Filter Examples") to its data source ("Titanic data"). Please help
AI Studio
Accepted answers
Caperez
Hi
@TuanNguyen
I had the same problem with a specific version of Rapidminer, something about of the metadata mapping. I solved it with a new installation of the last version.
please check that you have the last version.
Best,
Cesar
All comments
Caperez
Hi
@TuanNguyen
The connection is in the opposite way, the Out port of retrieve Titanic Dataset must be connected with the Exa port in Filter Examples operator.
Best
Cesar
TuanNguyen
Hello
ceaperez
Thank you for your answer.
I have followed the RM tutorials, and just done as you suggested (Out port from Titanic-training connected to Exa port of Filter Example).
However, when I tried to create a filter, the RM system did not show the list of attributes of Titatic data (which let me type manuallly the attribute name). I attempted to load the meta data of Titantic-training but the filter condition has not yet created.
I revisited the Tutorials and undertood that the reason is the Filter operator not connected to its data source (ie Titatic-training set) but did not know to fix this problem.
Please advise.
Caperez
Hi
@TuanNguyen
Best,
Cesar
MartinLiebig
Hi
@TuanNguyen
where did you take titanic from? The samples folder or a file?
If it is a file, please make sure to run the import wizard.
BR,
Martin
TuanNguyen
Thank you,
mschmitz
I took Titanic data from RM samples folder.
When I attempted to retrieve data from file with Import wizzard, data imports looks OK but my problem is still with Filter Example operator that could not show the list of attributes (inherently in meta data of Titanic), which forces me manually enter the name of attributes.
TuanNguyen
Hello
ceaperez
I will install the newest version of RM and retry it.
Thank you for your sharing.
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
