🎉Community Raffle - Win $25
Join and Win
Hi I've a question re Naive Bayes classifier and error I'm seeing
User: "Ado_on_the_Wing"
New Altair Community Member
Updated by Jocelyn
I hoped to run a Naive Bayes classifier on my simple dataset. I have 260 people records. There are ten independent attributes (about how people feel in wellness terms) and they're answered in simple binary form (unhappy = 1, otherwise =0) I have applied a class label to each of them, as in are they overall likely to be good next year or not.  It's telling me the numerical label is not supported...  Any help please? I'm only a newbie to this Community and also new to RapidMiner.. Thank you
1 - 2 of 21
    User: "BalazsBaranyRM"
    Hi!
    Naive Bayes in RapidMiner can only do classification. This means that your target (or label) attribute needs to be nominal (in this case binominal, having two possible nominal values). You can use Numerical to Binominal to change your attributes to the correct format. Or you could use Generate Attributes to change the numbers to the actual meaning:
    if([attribute] == 1, "unhappy", "otherwise")
    Naive Bayes will then work with the binominal label correctly.
    Regards,
    Balázs
    OP
    Thank you for this and apologies for my delayed response. I'll revert asap with how I get on.
