🎉Community Raffle - Win $25
Join and Win
Please help me interpret my results (totally newbie to this)
User: "Constantine"
New Altair Community Member
Updated by Jocelyn
Hey everyone,
I would like to ask you for help, in order to help me understand the results i have.
I am in the process of doing my thesis, and for this, i'm doing an RFM analysis on a big retailer, with the help of RapidMiner.
However, i frankly do not know 90% of the stuff that are going there, as my background is in marketing. My professor was very helpful and he taught me some things and how the tool works, and he made the xml process for me. Unfortunately, he got a nasty health issue and i don't want to bother him.
I have everything ready, and i'm fairly sure i can run it, with a bit of trouble with my potato of PC. The problem is, i do not know what to make of the results and would greatly appreciate if somebody spends 1-2h with me to help explain what i'm looking at. Please excuse me but i cannot provide the dataset as it's confidential. I will paste the process below.
Thank you in advance for all the help!
Kosta
<?xml version="1.0" encoding="UTF-8"?><process version="9.10.008">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.10.008" expanded="true" name="Process">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true">
      <operator activated="true" class="retrieve" compatibility="9.10.008" expanded="true" height="68" name="Retrieve sales" width="90" x="45" y="136">
        <parameter key="repository_entry" value="//krigas/sales"/>
      </operator>
      <operator activated="true" class="multiply" compatibility="9.10.008" expanded="true" height="145" name="Multiply" width="90" x="179" y="85"/>
      <operator activated="true" class="numerical_to_polynominal" compatibility="9.10.008" expanded="true" height="82" name="Numerical to Polynominal (2)" width="90" x="447" y="391">
        <parameter key="attribute_filter_type" value="single"/>
        <parameter key="attribute" value="item_id"/>
        <parameter key="attributes" value=""/>
        <parameter key="use_except_expression" value="false"/>
        <parameter key="value_type" value="numeric"/>
        <parameter key="use_value_type_exception" value="false"/>
        <parameter key="except_value_type" value="real"/>
        <parameter key="block_type" value="value_series"/>
        <parameter key="use_block_type_exception" value="false"/>
        <parameter key="except_block_type" value="value_series_end"/>
        <parameter key="invert_selection" value="false"/>
        <parameter key="include_special_attributes" value="false"/>
      </operator>
      <operator activated="true" class="aggregate" compatibility="9.10.008" expanded="true" height="82" name="Aggregate for F" width="90" x="380" y="136">
        <parameter key="use_default_aggregation" value="false"/>
        <parameter key="attribute_filter_type" value="all"/>
        <parameter key="attribute" value=""/>
        <parameter key="value_type" value="attribute_value"/>
        <parameter key="except_value_type" value="time"/>
        <parameter key="block_type" value="attribute_block"/>
        <parameter key="except_block_type" value="value_matrix_row_start"/>
        <parameter key="default_aggregation_function" value="average"/>
        <list key="aggregation_attributes">
          <parameter key="date_trns" value="count"/>
        </list>
        <parameter key="group_by_attributes" value="hh_id"/>
        <parameter key="count_all_combinations" value="false"/>
        <parameter key="only_distinct" value="false"/>
        <parameter key="ignore_missings" value="true"/>
      </operator>
      <operator activated="true" class="blending:sort" compatibility="9.10.008" expanded="true" height="82" name="Sort (2)" width="90" x="581" y="136">
        <list key="sort_by">
          <parameter key="hh_id" value="ascending"/>
        </list>
      </operator>
      <operator activated="true" class="aggregate" compatibility="9.10.008" expanded="true" height="82" name="Aggregate for R" width="90" x="380" y="238">
          <parameter key="date_trns" value="maximum"/>
        </list>
      </operator>
      <operator activated="true" class="generate_attributes" compatibility="9.10.008" expanded="true" height="82" name="Generate Attributes" width="90" x="581" y="238">
        <list key="function_descriptions">
          <parameter key="R_in_months" value="date_diff([maximum(date_trns)],date_parse_custom(&quot;03.03.2014&quot;,&quot;dd.MM.yyyy&quot;))/6.048e+8"/>
        </list>
        <parameter key="keep_all" value="true"/>
      </operator>
      <operator activated="true" class="select_attributes" compatibility="9.10.008" expanded="true" height="82" name="Select Attributes" width="90" x="715" y="238">
        <parameter key="attribute_filter_type" value="subset"/>
        <parameter key="attributes" value="hh_id|R_in_months"/>
      </operator>
      <operator activated="true" class="blending:sort" compatibility="9.10.008" expanded="true" height="82" name="Sort (3)" width="90" x="849" y="238">
        </list>
      </operator>
      <operator activated="true" class="aggregate" compatibility="9.10.008" expanded="true" height="82" name="Aggregate for M" width="90" x="380" y="34">
          <parameter key="price" value="sum"/>
        </list>
      </operator>
      <operator activated="true" class="blending:sort" compatibility="9.10.008" expanded="true" height="82" name="Sort" width="90" x="581" y="34">
        </list>
      </operator>
      <operator activated="true" class="concurrency:join" compatibility="9.10.008" expanded="true" height="82" name="Join" width="90" x="782" y="136">
        <parameter key="remove_double_attributes" value="true"/>
        <parameter key="join_type" value="inner"/>
        <parameter key="use_id_attribute_as_key" value="false"/>
        <list key="key_attributes">
          <parameter key="hh_id" value="hh_id"/>
        </list>
        <parameter key="keep_both_join_attributes" value="false"/>
      </operator>
      <operator activated="true" class="concurrency:join" compatibility="9.10.008" expanded="true" height="82" name="Join (2)" width="90" x="983" y="187">
        </list>
      </operator>
      <operator activated="true" class="retrieve" compatibility="9.10.008" expanded="true" height="68" name="Retrieve products" width="90" x="45" y="493">
        <parameter key="repository_entry" value="//krigas/products"/>
      </operator>
      <operator activated="true" class="numerical_to_polynominal" compatibility="9.10.008" expanded="true" height="82" name="Numerical to Polynominal" width="90" x="179" y="493">
        <parameter key="attributes" value="item_class_cd|item_id|item_sc_cd"/>
      </operator>
      <operator activated="true" class="generate_attributes" compatibility="9.10.008" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="380" y="493">
          <parameter key="product_categpory" value="concat(item_grp_cd,&quot;_&quot;,item_class_cd,&quot;_&quot;,item_sc_cd)"/>
        </list>
      </operator>
      <operator activated="true" class="concurrency:join" compatibility="9.10.008" expanded="true" height="82" name="Join (4)" width="90" x="715" y="493">
          <parameter key="item_id" value="item_id"/>
        </list>
      </operator>
      <operator activated="true" class="select_attributes" compatibility="9.10.008" expanded="true" height="82" name="Select Attributes (2)" width="90" x="849" y="493">
        <parameter key="attributes" value="hh_id|product_categpory|date_trns"/>
      </operator>
      <operator activated="true" class="aggregate" compatibility="9.10.008" expanded="true" height="82" name="Aggregate" width="90" x="983" y="493">
          <parameter key="product_categpory" value="count"/>
        </list>
      </operator>
      <operator activated="true" class="concurrency:join" compatibility="9.10.008" expanded="true" height="82" name="Join (3)" width="90" x="1117" y="238">
        </list>
      </operator>
      <operator activated="true" class="blending:rename" compatibility="9.10.008" expanded="true" height="82" name="Rename" width="90" x="1251" y="238">
        <list key="rename attributes">
          <parameter key="count(date_trns)" value="F"/>
          <parameter key="sum(price)" value="M"/>
          <parameter key="R_in_months" value="R"/>
          <parameter key="count(product_categpory)" value="V"/>
        </list>
        <parameter key="from_attribute" value=""/>
        <parameter key="to_attribute" value=""/>
      </operator>
      <operator activated="true" class="order_attributes" compatibility="9.10.008" expanded="true" height="82" name="Reorder Attributes" width="90" x="1385" y="238">
        <parameter key="sort_mode" value="user specified"/>
        <parameter key="attribute_ordering" value="hh_id|R|F|M"/>
        <parameter key="use_regular_expressions" value="false"/>
        <parameter key="handle_unmatched" value="append"/>
        <parameter key="sort_direction" value="ascending"/>
      </operator>
      <operator activated="true" class="select_attributes" compatibility="9.10.008" expanded="true" height="82" name="Select Attributes (3)" width="90" x="1519" y="238">
        <parameter key="attributes" value="F|M|R|V"/>
      </operator>
      <operator activated="true" class="normalize" compatibility="9.10.008" expanded="true" height="103" name="Normalize" width="90" x="1653" y="238">
        <parameter key="return_preprocessing_model" value="false"/>
        <parameter key="create_view" value="false"/>
        <parameter key="method" value="Z-transformation"/>
        <parameter key="min" value="0.0"/>
        <parameter key="max" value="1.0"/>
        <parameter key="allow_negative_values" value="false"/>
      </operator>
      <operator activated="true" breakpoints="before" class="concurrency:k_means" compatibility="9.10.008" expanded="true" height="82" name="Clustering" width="90" x="1787" y="238">
        <parameter key="add_cluster_attribute" value="true"/>
        <parameter key="add_as_label" value="false"/>
        <parameter key="remove_unlabeled" value="false"/>
        <parameter key="k" value="5"/>
        <parameter key="max_runs" value="10"/>
        <parameter key="determine_good_start_values" value="true"/>
        <parameter key="measure_types" value="BregmanDivergences"/>
        <parameter key="mixed_measure" value="MixedEuclideanDistance"/>
        <parameter key="nominal_measure" value="NominalDistance"/>
        <parameter key="numerical_measure" value="EuclideanDistance"/>
        <parameter key="divergence" value="SquaredEuclideanDistance"/>
        <parameter key="kernel_type" value="radial"/>
        <parameter key="kernel_gamma" value="1.0"/>
        <parameter key="kernel_sigma1" value="1.0"/>
        <parameter key="kernel_sigma2" value="0.0"/>
        <parameter key="kernel_sigma3" value="2.0"/>
        <parameter key="kernel_degree" value="3.0"/>
        <parameter key="kernel_shift" value="1.0"/>
        <parameter key="kernel_a" value="1.0"/>
        <parameter key="kernel_b" value="0.0"/>
        <parameter key="max_optimization_steps" value="100"/>
        <parameter key="use_local_random_seed" value="false"/>
        <parameter key="local_random_seed" value="1992"/>
      </operator>
      <connect from_op="Retrieve sales" from_port="output" to_op="Multiply" to_port="input"/>
      <connect from_op="Multiply" from_port="output 1" to_op="Aggregate for M" to_port="example set input"/>
      <connect from_op="Multiply" from_port="output 2" to_op="Aggregate for F" to_port="example set input"/>
      <connect from_op="Multiply" from_port="output 3" to_op="Aggregate for R" to_port="example set input"/>
      <connect from_op="Multiply" from_port="output 4" to_op="Numerical to Polynominal (2)" to_port="example set input"/>
      <connect from_op="Numerical to Polynominal (2)" from_port="example set output" to_op="Join (4)" to_port="left"/>
      <connect from_op="Aggregate for F" from_port="example set output" to_op="Sort (2)" to_port="example set input"/>
      <connect from_op="Sort (2)" from_port="example set output" to_op="Join" to_port="right"/>
      <connect from_op="Aggregate for R" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
      <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
      <connect from_op="Select Attributes" from_port="example set output" to_op="Sort (3)" to_port="example set input"/>
      <connect from_op="Sort (3)" from_port="example set output" to_op="Join (2)" to_port="right"/>
      <connect from_op="Aggregate for M" from_port="example set output" to_op="Sort" to_port="example set input"/>
      <connect from_op="Sort" from_port="example set output" to_op="Join" to_port="left"/>
      <connect from_op="Join" from_port="join" to_op="Join (2)" to_port="left"/>
      <connect from_op="Join (2)" from_port="join" to_op="Join (3)" to_port="left"/>
      <connect from_op="Retrieve products" from_port="output" to_op="Numerical to Polynominal" to_port="example set input"/>
      <connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/>
      <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Join (4)" to_port="right"/>
      <connect from_op="Join (4)" from_port="join" to_op="Select Attributes (2)" to_port="example set input"/>
      <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Aggregate" to_port="example set input"/>
      <connect from_op="Aggregate" from_port="example set output" to_op="Join (3)" to_port="right"/>
      <connect from_op="Join (3)" from_port="join" to_op="Rename" to_port="example set input"/>
      <connect from_op="Rename" from_port="example set output" to_op="Reorder Attributes" to_port="example set input"/>
      <connect from_op="Reorder Attributes" from_port="example set output" to_op="Select Attributes (3)" to_port="example set input"/>
      <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Normalize" to_port="example set input"/>
      <connect from_op="Normalize" from_port="example set output" to_op="Clustering" to_port="example set"/>
      <connect from_op="Clustering" from_port="cluster model" to_port="result 1"/>
    </process>
  </operator>
</process>
1 - 3 of 31
