🎉Community Raffle - Win $25
Join and Win
Auto Model one hot encoding
User: "Chemical_eng"
New Altair Community Member
Updated by Jocelyn
Hello, I am using automodel in rapid miner studio. The problem I have is that I have a categorical variable, therefore one hot encoding is needed. However, the number of categories is more than 50 , what can I do so the algorithm takes it into consideration and does not ignore it
1 - 4 of 41
    Hi,
    you can use the operator Replace Rare to replace Rare values with OTHER.
    BR,
    Martin
    Oh, alternatively you can use Target Encoding of course.
    OP
    Hi , thanks, I was using auto model in studio , I guess for this I need to export it into a process, where in the process I would need to add this ? thanks
    Hi,
    yes, or just do it up front with a small prep process. Please shoot me or Vlad an e-mail if you want to do this together with us.
    BR,
    Martin
