Rename by Replacing - REGEX
Hi All - struggling to utilize regex to rename columns after pivoting. Ideally trying to remove the "count(IDT)_" and leave the year on the header. Any help would be appreciated. XML and sample data attached.
<?xml version="1.0" encoding="UTF-8"?><process version="9.0.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="9.0.002" expanded="true" height="68" name="Read Excel (3)" width="90" x="112" y="1207">
<parameter key="excel_file" value="C:\Users\mdueber\OneDrive\OneDrive - JAGUAR LAND ROVER\Analytics Department\RapidMiner Support Files\RM on OneDrive Support\Service Retention\Data files\Car Parc\example2.xlsx"/>
<list key="annotations"/>
<parameter key="date_format" value="MMM d, yyyy h:mm:ss a z"/>
<list key="data_set_meta_data_information">
<parameter key="0" value="IDT.true.polynominal.attribute"/>
<parameter key="1" value="ZIP.true.polynominal.attribute"/>
<parameter key="2" value="COLOR.true.polynominal.attribute"/>
<parameter key="3" value="MODEL.true.polynominal.attribute"/>
<parameter key="4" value="SEGMENT.true.polynominal.attribute"/>
<parameter key="5" value="YEAR.true.integer.attribute"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="false"/>
<description align="center" color="transparent" colored="false" width="126">UIO</description>
</operator>
<operator activated="true" class="append" compatibility="9.0.002" expanded="true" height="82" name="Append (3)" width="90" x="313" y="1207"/>
<operator activated="true" class="filter_examples" compatibility="9.0.002" expanded="true" height="103" name="Filter Examples (4)" width="90" x="447" y="1207">
<list key="filters_list">
<parameter key="filters_entry_key" value="YEAR.ge.2012"/>
</list>
</operator>
<operator activated="true" class="numerical_to_polynominal" compatibility="9.0.002" expanded="true" height="82" name="Numerical to Polynominal" width="90" x="581" y="1156">
<parameter key="attribute_filter_type" value="subset"/>
<parameter key="attributes" value="YEAR"/>
</operator>
<operator activated="true" class="aggregate" compatibility="9.0.002" expanded="true" height="82" name="Aggregate (3)" width="90" x="782" y="1258">
<list key="aggregation_attributes">
<parameter key="IDT" value="count"/>
</list>
<parameter key="group_by_attributes" value="IDT|YEAR"/>
</operator>
<operator activated="true" class="pivot" compatibility="9.0.002" expanded="true" height="82" name="Pivot (3)" width="90" x="1050" y="1156">
<parameter key="group_attribute" value="IDT"/>
<parameter key="index_attribute" value="YEAR"/>
<parameter key="consider_weights" value="false"/>
<parameter key="skip_constant_attributes" value="false"/>
</operator>
<operator activated="true" class="concurrency:join" compatibility="9.0.002" expanded="true" height="82" name="Join (2)" width="90" x="1117" y="1258">
<list key="key_attributes">
<parameter key="IDT" value="IDT"/>
</list>
</operator>
<operator activated="true" class="rename_by_replacing" compatibility="9.0.002" expanded="true" height="82" name="Rename by Replacing" width="90" x="1251" y="1207">
<parameter key="attributes" value="count(IDT)"/>
<parameter key="regular_expression" value=".*count(VIN)"/>
<parameter key="include_special_attributes" value="true"/>
<parameter key="replace_what" value=" count"/>
</operator>
<connect from_op="Read Excel (3)" from_port="output" to_op="Append (3)" to_port="example set 1"/>
<connect from_op="Append (3)" from_port="merged set" to_op="Filter Examples (4)" to_port="example set input"/>
<connect from_op="Filter Examples (4)" from_port="example set output" to_op="Numerical to Polynominal" to_port="example set input"/>
<connect from_op="Numerical to Polynominal" from_port="example set output" to_op="Aggregate (3)" to_port="example set input"/>
<connect from_op="Aggregate (3)" from_port="example set output" to_op="Pivot (3)" to_port="example set input"/>
<connect from_op="Aggregate (3)" from_port="original" to_op="Join (2)" to_port="right"/>
<connect from_op="Pivot (3)" from_port="example set output" to_op="Join (2)" to_port="left"/>
<connect from_op="Join (2)" from_port="join" to_op="Rename by Replacing" to_port="example set input"/>
<connect from_op="Rename by Replacing" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
1 - 5 of
51
@BalazsBarany Thank you... I understand the escape character to recognize the parentheses but still having 2 issues
1 - not identifying the attributes
2 - regex still not recognizing the count\(IDT\)_ pattern to replace with nothing.
Any other ideas would be helpful
Hi!
In this case, you need the regexp in two places.
attribute filter type: regular_expression
regular expression: count\(IDT\)_.+ (the .+ is necessary because in this context RapidMiner wants to match the entire string)
replace what: count\(IDT\)_ (here it is fine without the .+ because we really just match this part of the string)
Regards,
Balázs
Regards,
Balázs
@BalazsBarany - Awesome thank you! That worked. Does the plus sign in this case just handle the way the "year' is handled in the attribute name? Thanks for the help!
1 - 1 of
11
Hi!
Regards,
Balázs
Regards,
Balázs
The parentheses in count(IDT)_ have a special meaning in regular expressions. This would be the correct one: count\(IDT\)_
Regards,
Balázs
