API engin error
I am working with RapidMiner for restaurant sentiment analysis. The error containing API engine error Expected a `:` after a key at 111 [character 112 line 1] appears whenever I run the software after using the sentiment analysis instruction. I am worn out of that. Could you help me why it happens and how I can solve this issue?
1 - 2 of
21
- Exception: com.rapidminer.operator.OperatorException
- Message: API Engine error: Expected a ':' after a key at 111 [character 112 line 1].
- Stack trace:
- com.MeaningCloud.extension.operator.SentimentOperator.doWork(SentimentOperator.java:138)
- com.rapidminer.operator.Operator.execute(Operator.java:1023)
- com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
- com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:805)
- com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:800)
- java.security.AccessController.doPrivileged(Native Method)
- com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:800)
- com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
- com.rapidminer.Process.executeRoot(Process.java:1464)
- com.rapidminer.Process.lambda$executeRootInPool$5(Process.java:1443)
- com.rapidminer.studio.concurrency.internal.AbstractConcurrencyContext$AdaptedCallable.exec(AbstractConcurrencyContext.java:362)
- java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)
- java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)
- java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)
- java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:175)
Hi there,
i am not sure I understand your problem. Can you please elaborate on it?
BR,
Martin
I am getting the same error. I am using MeaningCloud sentiment analysis operator to process data from Twitter. It seems that it hasnt loaded any sentiment models on the sentiment analysis operators - as you see on the screenshot the sentiment model field is empty and it doesnt give you any options, the same with User dictionaries. I have properly installed the licence key.
Thank you very much!
Dimi
Dimi
