I created a rapidminer process and I want to get it as an image for showing it in a paper. Is there a possibility to extract the process diretctly as a pdf or png, or do i have to make screenshots from the process?
Check out the Print/Export Image item in the File menu. It exports the full process as an image file or prints it. This is better than making screenshots for big processes that don't fit to the screen.
Regards,
Balázs
