Windows11- tabs and menu pop windows display errors
Hello, I try to transfer RM to a new notebook running Windows11 Pro with AMD processor and RTX GC.
Whereas the installation of RM was convenient, the different RM displays are not updating, freezing or mixing up with time.
It is the only Software on that computer that shows such behavior, so that some settings seem to be in need of adjustments.
Would be great to get an advice.
Best. T
1 - 3 of
31
Hello, thank you for the suggestions.
I added "%JAVA%" %JVM_OPTIONS% -Dsun.java2d.d3d=false -Dsun.java2d.opengl=true -cp "% to the batch file and started it.
Indeed it prevented the display errors - inducible by going to preferences/backend and click scroll down menu to the right.
However starting by using the old desktop shortcut took RM back to display error behavior.
Looks like I have to use a display shortcut for the batch file instead, because it gives a stable RM display, or add something into the shortcut properties.
Thank you.
T
Thank you.
T
1 - 1 of
11
Hi Tom,
sadly Windows 11 isn't officially supported yet by RapidMiner Studio.
I've also read that creating connections on Windows 11 might not work in another thread.
Can you try this for the graphical issues?
https://community.rapidminer.com/discussion/comment/70711/#Comment_70711
Greetings,
Jonas
Greetings,
Jonas
Greetings,
Jonas
