A absurd problem about "raplace missing value" operator
I used "filter examples " operator to handle missing values and I am sure there are no missing values after that. But when I used "cross validation" and "neural net" to be my testing model, Rapidminer showed me that "neural net cannot handle missing values". Then I clicked " help me to solve the problem", a "replace missing values" operator automatically appeared on my process. However, I still can't run my process because Rapidminer showed me "attribute filter does not match any attributes". Does it means I can't use "replace missing values" because there are no value missing? I really don't know how to solve this problem.
Could anyone help me? Thanks a lot!!
1 - 5 of
51
I clicked "help me to solve the problem" again after Rapidminer showed "attribute filter does not match any attributes". However, there was no any solution for me this time.
Hi @May_LIN_01,
Can you please provide your process and your dataset in order to reproduce the problem and in order to understand your problem ?
Regards,
Lionel
Regards,
Lionel
@lionelderkrikor,I ran my process successfully with your help! Thanks you so much for helping me solve the problem!
I suddenly realize that i didn't tell you what am i going to do, i mean the purpose of the whole process. So i think you will probably be confused... It's my first time to post on rapidminer community, so i don't know what should i do... Really sorry for that
Hope it haven't waste you a lot of time...
Regards,
May
Regards,
May
1 - 1 of
11
May,
You can find in attached file , the working process :
- I set your label attribute to NOMINAL
- I set your attributes "text" and " Title" to "Id" so that they are not taken into account by the model during training...
Have a nice day,
Regards,
Lionel
Have a nice day,
Regards,
Lionel
