🎉Community Raffle - Win $25
Join and Win
How can I change the content of the date_added Attribute to MM//dd/yy ?
User: "GeorgeOik1999"
New Altair Community Member
Updated by Jocelyn
Should I use Replace, Map or Generate Attribute? I tried to use Generate aatribute in order to create a new one that will describe the month and the year ( more importantly ) but my function was invalide. [ date_parse( concat ( str(month),"/",str(day),"/","year") )  ]
Thanks in advance.
1 - 1 of 11
    User: "Caperez"
    Accepted Answer
    Hi @GeorgeOik1999,
    You can use the Date to Nominal operator to transform your date attribute to a desired format.
    please find attached a simple sample.
    Best,
    Cesar
