I have a string "AGGRGATION_PERIODICITY=DAILY|DIRECTION=OUTWARD|FINANCIAL_PRODUCT=REMITTANCE" want to extract "DAILY" and store into new attribute PARAM_PERIODICITY
I would use Generate Attributes with a formula like replaceAll( attribute, ".+PERIODICITY=(.+)\\|DIRECTION.+", "$1") .
The regular expression searches for the appropriate string. If the format varies (e. g. DIRECTION is not always on the same place), you need to change the regular expression.
Regards,
Balázs
