Generate attribute
User: "Yinkz"
New Altair Community Member
Updated by Jocelyn
How do I define attribute range between 100 and 200 when using function under generate attribute?
1 - 2 of 21
    User: "Caperez"
    Accepted Answer
    Hi @Yinkz
    You can work with the rand() method into  the function expression editor.
    please find attached a simple process to generate  float and integer attributes.
    Best,
    Cesar
    User: "Yinkz"
    OP
    Thabk you @ceaperez. It worked.
