About Monkeylearn API connection
1 - 3 of
31
Hi,
I think they just don't propvide the 'new' connection management and you need to put your api token into each operator. @yyhuang you usedthis operator quite a bit? Don't you?
Best,
Martin
@mschmitz ah thank you for your help. I havent found a way to connect it to rapidminer after a few hours of struggling though ^_^. its a shame cus monkeylearn is really easy to use and beginner friendly. guess i will try to find other methods. Do you recommend the text processing extensions for these kind of problem ?
