compare labels
User: "SimonK"
New Altair Community Member
Updated by Jocelyn
Hello,
Is there a way to compare the predicted label and the actual label of unseen test data in the Model Simulator?
thanks in advance
Simon
1 - 6 of 61
    User: "Caperez"
    Updated by Caperez
    Hi @SimonK,
    There are three input ports in the Simulator Operator
    Mod, tra and tes.
    The tes port correspond to the test dataset. you can connect here an untried test dataset.
    Best.
    Cesar
    User: "SimonK"
    OP
    I would be interested in an output port where I can compare the predicted labels with the actual labels.
    Simon
    User: "Caperez"
    Hi @SimonK,
    could you explain in more detail what you need?
    Best,
    Cesar
    User: "SimonK"
    OP
    I would like to generate an ExampelSet where I compare the actual test values and the predicted test values. The Model Simulator only gives me an overall result, but I would like to compare the results in each row.
    Simon
    User: "Caperez"
    Accepted Answer
    Hi @SimonK,
    Did you try the Apply Model operator? Is that information not enough?
    Best.
    Cesar
    User: "SimonK"
    OP
    that was exactly the operator I was looking for.
    Thank you very much!
    Simon
