Correlation
A correlation can be found between binomial and numerical values.
However, this is not possible with polynomial attributes. We can determine this with the operator "Nominal to Numerical", but here the question arises whether this operator falsifies the result.
Is there another operator or another alternative?
1 - 1 of
11
Do you mind to share an example with us? I feel like I don't have enough information to give you an answer.
All the best,
Rod.
