Boolean Function for Elements?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I'm working with a model that contains 2 components.
1. Comp contains surfaces, solids and elements
2. Comp contains lines, surfaces and Elements. A solid can not be created from the surfaces.
I used another way though to create Tetraeder Elements to fill the volume contained by the surfaces.
The 2nd component is placed within the 1st component.
Now I want to cut out the space of the 1st comp, so that the 2nd comp fits in without having the elements of both
components overlap.
Basically I want to use a boolean function for elements, like the 'solid edit>boolean>A-B (del B )' function for solids.
But as I can't create a solid from the surfaces of the 2nd comp. I need to go another way than the traditional boolean.
Is there something like boolean for elements?
Kind regards,
Niclas_emi
