🎉Community Raffle - Win $25
Join and Win
How to store each iteration of the loop with different filenames ?
User: "Harshav"
New Altair Community Member
Updated by Jocelyn
Fore each iteration ,I get one dataframe which needs to be stored with the table name as table_name_{value}.Can you suggest me how to store all loop results with different table names
1 - 4 of 41
    User: "BalazsBaranyRM"
    Accepted Answer
    Hi,
    in the Write Database operator (and almost everywhere else) you can use macros in the "table name" parameter.
    It would be something like: table_name_%{loop_nr}
    The iteration number would be in a macro, this is mostly automatic with the Loop operators in RapidMiner.
    There are different videos for macros in the Academy if you'd like to learn more about them:
    https://academy.rapidminer.com/catalog?query=macros
    Regards,
    Balázs
    User: "Harshav"
    OP
    Hi balazs,
    Thank you for responding to the above problem. FYI I'm working in radoop nest and I could find only two operators loop and loop attributes .
    When I'm storing in hive database like you said table_name_%{loop_attribute} , I couldnt store in different tables since %{loop_attribute} is just column name. How do i store it with different names in this case ?
    P.S.- There is loop values that can be used in sparkrm but my whole process is built with radoop operators which needs to looped and store it with different names .
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hi,
    I think you can use the normal Generate Macro within a Radoop Nest. Not sure though - please give it a try.
    Best,
    Martin
    User: "Harshav"
    OP
    Thank you martin I used extract macro(sparkrm) in loop attributes and store it with different names in store in this format  table_name_%{macro} :)
