🎉Community Raffle - Win $25
Join and Win
How to replace one value as another value?
User: "Ellie98"
New Altair Community Member
Updated by Jocelyn
Hey there,
I want to change the "Together,Married, etc." values into "inRelationship" and "Single,Divorced, etc." into "Single". I'm not sure how to do it. Do I have the use the Map operator?
Thanks in advance!
1 - 3 of 31
    Yes, Map it is.
    User: "Ellie98"
    OP
    Is there any template to look it up? I'm not sure how to do it  @mschmitz
    User: "YYH"
    Altair Employee
    Accepted Answer
    Updated by YYH
    Hi @Ellie98, for new users, it is strongly recommended to learn the use of each operator through the help view. There is usually tutorial process for each operator. You can firstly find the operator that you wanna learn, check it out in the help view and follow the links to open the tutorial.
    HTH!
