How to export the result as a csv file when you run a process in AI Hub?
User: "tahsin"
New Altair Community Member
Updated by Jocelyn
Hello,
I am using Rapidminer AI Hub to schedule and monitor a process. Inside the process I am using a store operator which saves the final result. Since, the process is updating daily I want the final result as a csv format from the process. My question is, how can I get a CSV file as an output which gives me the final result when I run the process in AI Hub?
