🎉Community Raffle - Win $25
Join and Win
How to extract value from range by only using cut function in generate attribute
tomarriottUser: "tomarriott"
New Altair Community Member
Updated by Jocelyn
1 - 3 of 31
    CaperezUser: "Caperez"
    Accepted Answer
    Updated by Caperez
    Hi @tomarriott
    The cut function "cut" the nominal attribute using the position of characters. the first argument is the attribute, the second argument is to know from where begin to count and the third argument is for the lenght of extracted string.
    for the example propused in your message, in order to extract the "1" character from the attribute, the configuration of cut function must be
    cut(yournominalattribute,3,4)
    Best
    If there have 22 samples in an attribute Maximum(order_data), can I formate formulas cut(Maximum(order_data),1,22) in order to count all example
    Accepted Answer
    Hi @tomarriott,
    The function cut works in any row of your attribute (colum)
    taking for example the first row in your attribute Maximum(order_data) [-∞ -38.0] the [ corresponds to 0 position, - corresponds to 1 position, etc.
    if you want to extract the "38" characters your cut function must be like cut(Maxi, 4, 2). This cut function will extract the string "0-" in second row.
     make sure that your attribute is nominal
    Best
