🎉Community Raffle - Win $25
Join and Win
Removing a word from list of words
User: "Anusha"
New Altair Community Member
Updated by Jocelyn
Hello All!
a dataset has 2 columns, one column has a list of words, I want to remove the last word including special characters(in this eg,   [,.?]) is it possible?
Source data:
reg_no      text
1               In,a,data,base,,,
2               at,palace,he,has,?,????,
required data:
reg_no     text
1              In,a,data
2              at,palace,he
1 - 1 of 11
    User: "kayman"
    Accepted Answer
    Updated by kayman
    @Anusha, use regex.
    The idea is that you want to keep everything till the last comma followed by a word.
    ^(.*),\w+.*
    Not fully tested but it should do the trick.
    use the replace operator with above snippet, and replace with $1
    You can play with the regex here :
    https://regex101.com/r/URTvjo/1
