Two-Way ANOVA
Emma_Litfin
New Altair Community Member
Hello
Is two-way ANOVA possible in RM?
I have one numerical attribute (e.g. a score out of 100) and two nominal attributes with varying classes (e.g. age group (18-21, 22-25, etc) and student status (domestic, international)).
I've been able to get Grouped ANOVA to work for the numerical attribute and one nominal attribute, but it doesn't allow for two nominal attributes.
Thanks
Emma
Thanks
Emma
0
Answers
Hi @Emma_Litfin,
you can handle this running a python script into RM. here is a simple code to perform the Two-way Anova with Golf dataset from examples.
Just connect your dataset output port to the inp port and edit the python script. please see attached the python script as txt
Regards0 -
There is also the Statistics extension which can be obtained in the Marketplace which allows ANOVA (and other statistical tests) to be performed directly within RapidMiner using operators.0
