delay prediction sample shows no results
Eri
New Altair Community Member
Best Answer
@Eri,
You have only 2 attributes in your dataset :
- the Schiff-Code
AND
- the verspätung ( a priori the attribute you want to predict).
With these data alone, it is impossible to predict anything....
- You need a priori additional independent explanatory variables to predict something...
OR
- You need a time series , for example :
for a given vessel, the delays during the date (t-i), ..... ,date (t-2), date( t-1), date( t), in order to predict the delay of the vessel at the date (t+1).
Hope this helps,
Regards,
Lionel
0
Answers
Hi @Eri
I think that the community will have some difficulties to understand what is going on with so few information.
Can you elaborate ? Can you describe what you initially have, what do you expect and ideally can you share your dataset in order we can reproduce what you observe ?
Thank you for your understanding,
Regards,
Lionel1 -
I have a A,B,C... etc vessels and delays (+ - too late; - too early) in the last period.0
@Eri,
- the Schiff-Code
AND
OR
Hope this helps,
Regards,
Lionel
0
