Hello. I am using the operators: Process Documents from Files, and inside that there are Tokenize, Filter stopwords, Stem, Transform cases (please see xml attached). The output exa and wor are both connected to res ports. When checking the results panel there are two tabs. WordList and ExampleSet (see attached). I would think that I would want to create a word cloud from the output of the WordList (in particular from either Total Occurances or Document Occurances). However in the WordList display there is no button for Visualizations in this tab (there is for the ExampleSet tab). Can someone guide me from here to create the word cloud? Thank you!
