🎉Community Raffle - Win $25
Join and Win
set label in data permanently
User: "wclaster"
New Altair Community Member
Updated by Jocelyn
Hello. The sample data in RM studio has a data set called Titanic Training data which has the label already set to the survive attribute. Is there some way to permanently set an attribute as the label so that you don't have to use the set role operator? Thank you.
1 - 2 of 21
    User: "Caperez"
    Accepted Answer
    Hi @wclaster
    If you store your preprocessed data in your repositories using the Store operator, you can use it in other models and data will conserve the roles and types assigned.
    regards
    User: "wclaster"
    OP
    Thank you!
