🎉Community Raffle - Win $25
Join and Win
update a dataset
User: "sepiol79"
New Altair Community Member
Updated by Jocelyn
Good evening I want to generate two new attributes (lat,lng) to the dataset of frauds and fill them with the lat and long of another dataset
1 - 2 of 21
    User: "Marco_Barradas"
    Altair Employee
    Accepted Answer
    Hi @sepiol79 I saw the info of your excel file. I can´t run the process you ran because the example sets are not shared with the process you uploaded.
    I guess you are going to join them by TransferID you will need to add a Join Operator to your process and under the parameters click on the pick attributes and select the info that you have on both datasets.
    Hope that helps you.
    User: "sepiol79"
    OP
    Accepted Answer
    thanks a lot @MarcoBarradas
