Create new connections for Aylien and Rosette
User: "qchung"
New Altair Community Member
Updated by Jocelyn
How do I create new connections in RapidMiner Studio 9.3 for Aylien and Rosette? Which connection type should I choose? I understand Aylien is no longer supported, but both Aylien and Rosette worked just a few months ago in the previous release. Is there a way to convert "legacy connections" of Aylien and Rosette into new connections? Thank you in advance.
1 - 6 of 61
    User: "YYH"
    Altair Employee
    Accepted Answer
    Updated by YYH
    Hi @qchung,
    Good question. Right now we haven't finish re-do all the connections. You don't need to convert the legacy connections of Aylien/Rosette into the new connections.
    We still have access to the legacy connections and manage them thru
    Connections -> Legacy Connections -> Manage Connections (Legacy)
    Hope it helps.
    YY
    User: "qchung"
    OP
    Thanks! Hearing that RapidMiner hasn't finished migration of old connections gave me a great relief, because it implies it will happen soon - if not done already.
    Hi,
    Just a heads up: Aylien/Rosette are 3rd party extensions, they are not maintained by RapidMiner. We have converted all our supported extensions by now and made them available on the Marketplace.
    Regards,
    Marco
    User: "bimatirta"
    I would like to analyze sentiment with Twitter data. But there is no Rosette or Aylien in the marketplace. What is your solution for me?
    User: "bimatirta"
    I just make a connection and still can't read the connection. Please help me!
    User: "Telcontar120"
    The reason those extensions are no longer available in the Marketplace is because the vendors who originally created them have not updated them to be compatible with the latest version of RapidMiner. You should look at some of the current alternatives. If you want to do a simple sentiment analysis you can use the operator created by RapidMiner to do this (it is part of the free Operator Toolbox extension).
