🎉Community Raffle - Win $25
Join and Win
SMOTE Upsampling Operator With Multi-Label Classification
User: "Nawaf"
New Altair Community Member
Updated by Jocelyn
Hi!
 I wanted to ask if it is possible to use SMOTE Upsampling operator with multi-label classification? If so how? If not what is the alternative operator to overcome imbalanced classes?
1 - 4 of 41
    Hi @nawaf,
    sure. you just use it #classes-1 times to get all classes to the same level.
    Best,
    Martin
    User: "David_A"
    Hi @Nawaf ,
    you could simply run SMOTE multiple time for the minority classes. So afterwards you have an up-sampled data set with all classes being balanced. Of course this is only really feasible when the number of classes is not too high.
    Best,
    David
    User: "Nawaf"
    OP
    Thanks folks for your response! The number of difference between class 0 and 1 (using the binary classification) is almost too high as normal for multi-label classification problem. So do you think finding the best threshold is better than applying SMOTE ?
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    good question. Both ways are feasible and can be succesful. What I would remind you about is, that if you use tree-based models like a RF then the additional examples from upsampling allows "deeper trees", since there are just more examples. You this get a very different tree.
    Best,
    Martin
