I am getting - Error executing background job 'Creating Display' java.lang.NullPointerException
Following are the other details of the error.
- Exception: java.lang.NullPointerException
- Message: null
- Stack trace:
- edu.uci.ics.jung.algorithms.layout.ISOMLayout.adjustVertex(ISOMLayout.java:176)
- edu.uci.ics.jung.algorithms.layout.ISOMLayout.adjust(ISOMLayout.java:139)
- edu.uci.ics.jung.algorithms.layout.ISOMLayout.step(ISOMLayout.java:107)
- edu.uci.ics.jung.algorithms.layout.LayoutDecorator.step(LayoutDecorator.java:58)
- edu.uci.ics.jung.visualization.layout.ObservableCachingLayout.step(ObservableCachingLayout.java:59)
- edu.uci.ics.jung.algorithms.layout.util.VisRunner.prerelax(VisRunner.java:62)
- edu.uci.ics.jung.visualization.DefaultVisualizationModel.setGraphLayout(DefaultVisualizationModel.java:113)
- edu.uci.ics.jung.visualization.DefaultVisualizationModel.(DefaultVisualizationModel.java:74)
- edu.uci.ics.jung.visualization.DefaultVisualizationModel.(DefaultVisualizationModel.java:58)
- edu.uci.ics.jung.visualization.VisualizationViewer.(VisualizationViewer.java:63)
- com.rapidminer.gui.graphs.GraphViewer$1.(GraphViewer.java:158)
- com.rapidminer.gui.graphs.GraphViewer.(GraphViewer.java:158)
- com.rapidminer.gui.renderer.AbstractGraphRenderer.createReportable(AbstractGraphRenderer.java:95)
- com.rapidminer.gui.processeditor.results.SingleResultOverview.(SingleResultOverview.java:190)
- com.rapidminer.gui.processeditor.results.ProcessExecutionResultOverview.(ProcessExecutionResultOverview.java:209)
- com.rapidminer.gui.processeditor.results.ResultOverview.addResults(ResultOverview.java:128)
- com.rapidminer.gui.processeditor.results.DockableResultDisplay$2.run(DockableResultDisplay.java:217)
- com.rapidminer.gui.tools.ProgressThread$3.run(ProgressThread.java:586)
- java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
- java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
- java.lang.Thread.run(Thread.java:748)
Can anyone help me out with this.
1 - 3 of
31
I have a set of documents which I want to compare using data to similarity function. Earlier it was working. But now it is giving me error. need your expert help in this matter. thanks
