MS SQL server connection parameters?
User: "RuuddB"
New Altair Community Member
Updated by Jocelyn
Hello,
We are using an MS SQL server local installation (on a laptop) and Microsoft SQL Management Server Studio to perform queries.
How can I connect to this database? Do I need to add a custom JDBC driver or not? And what are the parameters I
need to enter when specifying the connection (as given in your instruction video ( which link I cannot use)
Best regards,
Ruud
1 - 2 of 21
    User: "BalazsBaranyRM"
    Hi Ruud,
    yes, you need to have a JDBC driver. The parameters are documented on the homepage of the MS SQL JDBC driver:
    https://docs.microsoft.com/en-us/sql/connect/jdbc/setting-the-connection-properties?view=sql-server-ver15
    The exact settings depend on your database. For example, if you use integrated authentication or database users with passwords.
    Which link didn't work for you?
    Regards,
    Balázs
    User: "RuuddB"
    OP
    Hi Balázs,
    I would like to test the JDBC driver somehow. There might be problems regarding the Java runtime (did I install it, can it be found, etc).
    Also, I don't know what to use for host and database name.
    Using C# to connect to the database, I have the following parameters:
    "Data Source=<computername>\\SQLEXPRESS;Initial Catalog=<databasename>;User ID=sa;Password=xxx"
    Any suggestions how to do this? Using the rapidminer "Test" button only gives me very limited information
    It tells me a timeout occurred.
    Regards,
    Ruud
