1 - 4 of
41
@Clenterra
I see from the log that you were running out of memory. Make sure that you close all other applications when you start the install and that your computer meets the minimum requirements.
How much memory do you have?
regards,
Alex
regards,
Alex
I didn't have a problem installing 9.8 over 9.72 so this might just affect a fresh install.
@Clenterra, I am looking for a workaround so check back here soon. This is probably only affecting certain users.
regards,
Alex
