🎉Community Raffle - Win $25
Join and Win
How can we copy the result?
User: "Mac2020"
New Altair Community Member
Updated by Jocelyn
When we finish the process, how can we copy the result from the process into excel or word file
1 - 5 of 51
    Hi,
    you usually use a Write Excel operator as last operator. This way it is stored if you run the process.
    ~Martin
    User: "Mac2020"
    OP
    Hi Martin,
    Thank you for your suggestion.
    If I want copy tree (from decision tree) picture, how can I copy into excel or word or pdf file.
    User: "Telcontar120"
    You can export the tree using the Print/Export image option under the File menu.
    Otherwise you could look into the Reporting extension, which has more sophisticated options for outputting many different types of RapidMiner elements into reports.
    User: "Mac2020"
    OP
    Could you please suggestion that how can we use Reporting extension? and where can we find this manu?
    Thanks
    User: "Mac2020"
    OP
    Hello Telcontar120 or Rapidminer team,
    I am still waiting your suggestion as above question.
    Thanks
