🎉Community Raffle - Win $25
Join and Win
Deep Learning 1.0 Error when testing regression-style problems
User: "jacobcybulski"
New Altair Community Member
Updated by Jocelyn
When training a model on a regression data, i.e. with numerical label (such as "sea shells ages"), the model trains fine with training data only. When we connect the test port (e.g. by splitting data into training and testing partition), the following error is generated:
Oct 21, 2020 9:06:59 PM WARNING: Example set has no nominal label: using shuffled partition instead of stratified partition
Oct 21, 2020 9:06:59 PM SEVERE: Process failed: operator cannot be executed (The method getNominalMapping() is not supported by numerical attributes! You probably tried to execute an operator on a numerical data which is only able to handle nominal values. You could use one of the discretization operators before this application.). Check the log messages...
When we train the model on a classification data, i.e. with a nominal label (such as "iris flowers"), the process completes without any problems.
I am running those examples with Deep Learning extension 1.0, on RapidMiner 9.8, with CPU-OpenBLAS and with GPU-CUDA (CUDA 10.1), on Ubuntu 18.04 and Ubuntu 20.04.
Here is a modified "sea shells ages" sample process (the "Deep Learning" operator has not been altered).
<?xml version="1.0" encoding="UTF-8"?><process version="9.8.000">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process" origin="GENERATED_SAMPLE">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true">
      <operator activated="true" class="retrieve" compatibility="9.8.000" expanded="true" height="68" name="Retrieve Abalone" origin="GENERATED_SAMPLE" width="90" x="45" y="34">
        <parameter key="repository_entry" value="//Samples/Deep Learning/data/Abalone"/>
        <description align="center" color="transparent" colored="false" width="126">Loading data</description>
      </operator>
      <operator activated="true" class="set_role" compatibility="9.8.000" expanded="true" height="82" name="Set Role" origin="GENERATED_SAMPLE" width="90" x="45" y="136">
        <parameter key="attribute_name" value="Age"/>
        <parameter key="target_role" value="label"/>
        <list key="set_additional_roles"/>
      </operator>
      <operator activated="true" class="nominal_to_numerical" compatibility="9.8.000" expanded="true" height="103" name="Nominal to Numerical" origin="GENERATED_SAMPLE" width="90" x="45" y="238">
        <parameter key="return_preprocessing_model" value="false"/>
        <parameter key="create_view" value="false"/>
        <parameter key="attribute_filter_type" value="all"/>
        <parameter key="attribute" value=""/>
        <parameter key="attributes" value=""/>
        <parameter key="use_except_expression" value="false"/>
        <parameter key="value_type" value="nominal"/>
        <parameter key="use_value_type_exception" value="false"/>
        <parameter key="except_value_type" value="file_path"/>
        <parameter key="block_type" value="single_value"/>
        <parameter key="use_block_type_exception" value="false"/>
        <parameter key="except_block_type" value="single_value"/>
        <parameter key="invert_selection" value="false"/>
        <parameter key="include_special_attributes" value="false"/>
        <parameter key="coding_type" value="dummy coding"/>
        <parameter key="use_comparison_groups" value="false"/>
        <list key="comparison_groups"/>
        <parameter key="unexpected_value_handling" value="all 0 and warning"/>
        <parameter key="use_underscore_in_name" value="false"/>
      </operator>
      <operator activated="true" class="split_data" compatibility="9.8.000" expanded="true" height="124" name="Split Data" origin="GENERATED_SAMPLE" width="90" x="179" y="238">
        <enumeration key="partitions">
          <parameter key="ratio" value="0.6"/>
          <parameter key="ratio" value="0.2"/>
        </enumeration>
        <parameter key="sampling_type" value="automatic"/>
        <parameter key="use_local_random_seed" value="false"/>
        <parameter key="local_random_seed" value="1992"/>
      </operator>
      <operator activated="true" class="deeplearning:dl4j_sequential_neural_network" compatibility="1.0.000" expanded="true" height="145" name="Deep Learning" origin="GENERATED_SAMPLE" width="90" x="380" y="34">
        <parameter key="loss_function" value="Mean Squared Error (Linear Regression)"/>
        <parameter key="epochs" value="70"/>
        <parameter key="use_early_stopping" value="false"/>
        <parameter key="condition_strategy" value="score improvement"/>
        <parameter key="patience" value="5"/>
        <parameter key="minimal_score_improvement" value="0.0"/>
        <parameter key="best_epoch_score" value="0.01"/>
        <parameter key="max_iteration_score" value="3.0"/>
        <parameter key="max_iteration_time" value="10"/>
        <parameter key="use_miniBatch" value="false"/>
        <parameter key="batch_size" value="4"/>
        <parameter key="updater" value="Adam"/>
        <parameter key="learning_rate" value="0.01"/>
        <parameter key="momentum" value="0.9"/>
        <parameter key="rho" value="0.95"/>
        <parameter key="epsilon" value="1.0E-6"/>
        <parameter key="beta1" value="0.9"/>
        <parameter key="beta2" value="0.999"/>
        <parameter key="RMSdecay" value="0.95"/>
        <parameter key="weight_initialization" value="Xavier"/>
        <parameter key="bias_initialization" value="0.0"/>
        <parameter key="use_regularization" value="false"/>
        <parameter key="l1_strength" value="0.1"/>
        <parameter key="l2_strength" value="0.1"/>
        <parameter key="optimization_method" value="Stochastic Gradient Descent"/>
        <parameter key="cudnn_algo_mode" value="Prefer fastest"/>
        <parameter key="backpropagation" value="Standard"/>
        <parameter key="backpropagation_length" value="50"/>
        <parameter key="infer_input_shape" value="true"/>
        <parameter key="network_type" value="Simple Neural Network"/>
        <parameter key="log_each_epoch" value="true"/>
        <parameter key="epochs_per_log" value="10"/>
          <operator activated="true" class="deeplearning:dl4j_dense_layer" compatibility="1.0.000" expanded="true" height="68" name="Add Fully-Connected Layer" origin="GENERATED_SAMPLE" width="90" x="112" y="136">
            <parameter key="neurons" value="8"/>
            <parameter key="activation_function" value="ReLU (Rectified Linear Unit)"/>
            <parameter key="use_dropout" value="false"/>
            <parameter key="dropout_rate" value="0.25"/>
            <parameter key="overwrite_networks_weight_initialization" value="false"/>
            <parameter key="weight_initialization" value="Normal"/>
            <parameter key="overwrite_networks_bias_initialization" value="false"/>
            <description align="center" color="transparent" colored="false" width="126">Number of input attributes - number of output neurons&lt;br&gt;= 9 - 1 = 8.</description>
          </operator>
          <operator activated="true" class="deeplearning:dl4j_dense_layer" compatibility="1.0.000" expanded="true" height="68" name="Add Fully-Connected Layer (2)" origin="GENERATED_SAMPLE" width="90" x="313" y="136">
            <parameter key="neurons" value="1"/>
            <parameter key="activation_function" value="None (identity)"/>
            <description align="center" color="transparent" colored="false" width="126">Number of neurons = 1 because one value is estimated. And &amp;quot;None (Identity)&amp;quot; is chosen because a regression is performed.</description>
          </operator>
          <connect from_port="in layerArchitecture" to_op="Add Fully-Connected Layer" to_port="layerArchitecture"/>
          <connect from_op="Add Fully-Connected Layer" from_port="layerArchitecture" to_op="Add Fully-Connected Layer (2)" to_port="layerArchitecture"/>
          <connect from_op="Add Fully-Connected Layer (2)" from_port="layerArchitecture" to_port="out layerArchitecture"/>
          <portSpacing port="source_in layerArchitecture" spacing="0"/>
          <portSpacing port="sink_out layerArchitecture" spacing="0"/>
          <description align="center" color="yellow" colored="false" height="281" resized="true" width="190" x="62" y="46">The number of neurons chosen is selected by a rule of thumb here:</description>
          <description align="center" color="yellow" colored="false" height="325" resized="true" width="195" x="271" y="47">The last layer of the network. Notice how number of neurons and the activation function are chosen.</description>
        </process>
      </operator>
      <operator activated="true" class="apply_model" compatibility="9.8.000" expanded="true" height="82" name="Apply Model" origin="GENERATED_SAMPLE" width="90" x="581" y="238">
      </operator>
      <operator activated="true" class="performance_regression" compatibility="9.8.000" expanded="true" height="82" name="Performance" origin="GENERATED_SAMPLE" width="90" x="715" y="238">
        <parameter key="main_criterion" value="first"/>
        <parameter key="root_mean_squared_error" value="false"/>
        <parameter key="absolute_error" value="false"/>
        <parameter key="relative_error" value="true"/>
        <parameter key="relative_error_lenient" value="false"/>
        <parameter key="relative_error_strict" value="false"/>
        <parameter key="normalized_absolute_error" value="false"/>
        <parameter key="root_relative_squared_error" value="false"/>
        <parameter key="squared_error" value="false"/>
        <parameter key="correlation" value="false"/>
        <parameter key="squared_correlation" value="false"/>
        <parameter key="prediction_average" value="false"/>
        <parameter key="spearman_rho" value="false"/>
        <parameter key="kendall_tau" value="false"/>
        <parameter key="skip_undefined_labels" value="true"/>
        <parameter key="use_example_weights" value="true"/>
      </operator>
      <connect from_op="Retrieve Abalone" from_port="output" to_op="Set Role" to_port="example set input"/>
      <connect from_op="Set Role" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/>
      <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Split Data" to_port="example set"/>
      <connect from_op="Split Data" from_port="partition 1" to_op="Deep Learning" to_port="training set"/>
      <connect from_op="Split Data" from_port="partition 2" to_op="Deep Learning" to_port="test set"/>
      <connect from_op="Split Data" from_port="partition 3" to_op="Apply Model" to_port="unlabelled data"/>
      <connect from_op="Deep Learning" from_port="model" to_op="Apply Model" to_port="model"/>
      <connect from_op="Deep Learning" from_port="history" to_port="result 3"/>
      <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
      <connect from_op="Performance" from_port="performance" to_port="result 1"/>
      <connect from_op="Performance" from_port="example set" to_port="result 2"/>
      <portSpacing port="sink_result 3" spacing="0"/>
      <portSpacing port="sink_result 4" spacing="0"/>
    </process>
  </operator>
</process>
Jacob
1 - 5 of 51
    OP
    This is a full log from start to end, with the error in the middle.
    Oct 21, 2020 9:34:45 PM com.rapidminer.gui.RapidMinerGUI run
    INFO: Launching RapidMiner 9.8.000, platform ANY
    Oct 21, 2020 9:34:45 PM com.rapidminer.tools.I18N <clinit>
    INFO: Set locale to en.
    Oct 21, 2020 9:34:45 PM com.rapidminer.tools.PlatformUtilities logInfo
    INFO: rapidminer.home is '/home/jacob/Apps/rapidminer-studio-9-8'.
    Oct 21, 2020 9:34:46 PM com.rapidminer.tools.ProxySettings$ProxyVoleLogger log
    INFO: Gnome settings: /home/jacob/.gconf/system/proxy/%gconf.xml not found.
    INFO: Gnome settings: /home/jacob/.gconf/system/http_proxy/%gconf.xml not found.
    Oct 21, 2020 9:34:46 PM com.rapidminer.core.license.ProductConstraintManager initialize
    INFO: Initializing license manager.
    INFO: Using default license location.
    INFO: Registering default product.
    Oct 21, 2020 9:34:46 PM com.rapidminer.repository.FileRepositoryProvider load
    WARNING: Unknown tag: filesystemRepository
    Oct 21, 2020 9:34:46 PM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
    INFO: Global Search category repository registered.
    Oct 21, 2020 9:34:46 PM com.rapidminer.tools.plugin.Plugin registerPlugins
    INFO: Register plugin: Feature-Selection-Extension
    Oct 21, 2020 9:34:47 PM com.rapidminer.tools.plugin.Plugin registerPlugins
    INFO: Register plugin: Anomaly Detection
    INFO: Register plugin: Converters
    INFO: Register plugin: Deep Learning
    INFO: Register plugin: ND4J
    INFO: Register plugin: Operator Toolbox
    INFO: Register plugin: Custom Operators
    INFO: Register plugin: Python Scripting
    INFO: Register plugin: Shapelet
    INFO: Register plugin: Smile
    INFO: Register plugin: Statistics Extension
    INFO: Register plugin: Text Processing
    INFO: Register plugin: Web Mining
    INFO: Register plugin: Word2Vec
    INFO: Register plugin: Wordnet
    INFO: Register plugin: Process Scheduling
    INFO: Register plugin: HTML5 Charts
    INFO: Register plugin: Remote Repository
    INFO: Register plugin: Model Simulator
    INFO: Register plugin: JDBC Connectors
    INFO: Register plugin: Data Editor
    INFO: Register plugin: Professional
    INFO: Register plugin: Cloud Connectivity
    INFO: Register plugin: Blending
    INFO: Register plugin: Advanced File Connectors
    INFO: Register plugin: Productivity
    INFO: Register plugin: Browser
    INFO: Register plugin: Model Deployment Management
    INFO: Register plugin: Time Series
    INFO: Register plugin: Concurrency
    INFO: Register plugin: Utility
    INFO: Register plugin: Operator Recommender
    INFO: Register plugin: H2O
    INFO: Register plugin: Legacy Result Access
    INFO: Register plugin: Social Media
    INFO: Register plugin: CTA
    Oct 21, 2020 9:34:48 PM com.rapidminer.tools.ClassColorMap parseKey
    SEVERE: Unknown IO class: com.rapidminer.extension.operator.regression.LassoRegressionModel
    SEVERE: Unknown IO class: com.rapidminer.extension.ioobjects.ExampleIOObject
    Oct 21, 2020 9:34:49 PM com.rapidminer.tools.config.ConfigurationManager register
    INFO: Registered configurator Twitter Connection.
    Oct 21, 2020 9:34:50 PM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
    INFO: Async: Init browser setup.
    Oct 21, 2020 9:34:50 PM com.rapidminer.tools.config.ConfigurationManager register
    INFO: Registered configurator Salesforce Connection.
    INFO: Registered configurator Amazon S3 Connection.
    INFO: Registered configurator Azure Blob Storage Connection.
    INFO: Registered configurator Azure Data Lake Storage Gen1 Connection.
    INFO: Registered configurator gui.configurable.cloud.azure.gen2.name.
    INFO: Registered configurator Google Cloud Storage Connection.
    INFO: Registered configurator Dropbox Connection.
    Oct 21, 2020 9:34:51 PM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
    INFO: Async: Basic browser setup test starting.
    Oct 21, 2020 9:34:52 PM com.rapidminer.extension.jdbc.tools.jdbc.JDBCProperties <init>
    WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
    WARNING: Missing database driver class name for Ingres
    Oct 21, 2020 9:34:52 PM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
    INFO: Async: Created basic browser instance.
    INFO: Async: Loaded basic browser test content. Executing functionality check.
    INFO: Async: Basic browser setup test successful.
    Oct 21, 2020 9:34:52 PM com.rapidminer.extension.nd4j.PluginInitND4J initPlugin
    INFO: Setting up configuration handler
    INFO: Starting environment handler initialization with: GPU-CUDA
    Oct 21, 2020 9:34:52 PM com.rapidminer.extension.nd4j.tool.JarTool unzipAndLoadLibs
    INFO: Start unzipping and loading libraries: JarContext{archive=java.util.jar.JarFile@30ca0779, pluginId='rmx_nd4j', artifacts=[nd4j-linux-libs-1.0.0-all.jar, gpu-backend-cuda-1.0.0-all.jar]}
    Oct 21, 2020 9:34:52 PM com.rapidminer.extension.nd4j.tool.ReflectionTool extendClassloader
    INFO: Extending classloader with: [/home/jacob/.RapidMiner/managed/workspace/rmx_nd4j/gpu-backend-cuda-1.0.0-all.jar, /home/jacob/.RapidMiner/managed/workspace/rmx_nd4j/nd4j-linux-libs-1.0.0-all.jar]
    INFO: Lib file on class path: /home/jacob/.RapidMiner/managed/workspace/rmx_nd4j/gpu-backend-cuda-1.0.0-all.jar
    INFO: Lib file on class path: /home/jacob/.RapidMiner/managed/workspace/rmx_nd4j/nd4j-linux-libs-1.0.0-all.jar
    INFO: Extracting and loading libraries took 1ms.
    Oct 21, 2020 9:34:52 PM com.rapidminer.extension.nd4j.environment.EnvironmentHandlerImpl initializeAsync
    INFO: Running necessary pre-flight checks and waiting for their result
    Oct 21, 2020 9:34:52 PM com.rapidminer.extension.nd4j.tool.ReflectionTool executePreFlightCheck
    INFO: Executing pre-flight checks for backend (blas): CUBLAS
    Oct 21, 2020 9:34:53 PM com.rapidminer.extension.nd4j.tool.PreFlightCheck execute
    INFO: Executing test for CUBLAS - org.nd4j.linalg.jcublas.JCublasBackend
    Oct 21, 2020 9:34:55 PM com.rapidminer.extension.nd4j.tool.ReflectionTool resetNativeOpsHolder
    INFO: Resetting native operations holder for: org.nd4j.linalg.jcublas.JCublasBackend
    Oct 21, 2020 9:34:56 PM com.rapidminer.extension.nd4j.tool.ReflectionTool executePreFlightCheck
    INFO: Pre-flight result -> backend: CUBLAS, available: true
    Oct 21, 2020 9:34:56 PM com.rapidminer.extension.nd4j.environment.EnvironmentHandlerImpl initializeAsync
    INFO: Starting asynchronous backend initialization
    Oct 21, 2020 9:34:56 PM com.rapidminer.extension.nd4j.environment.EnvironmentHandlerImpl doInitializeAsync
    INFO: Availability: license=true, MKL=false, GPU=true
    Oct 21, 2020 9:34:56 PM com.rapidminer.extension.nd4j.environment.EnvironmentHandlerImpl lambda$doInitializeAsync$1
    INFO: Starting initialization with real-target: GPU-CUDA
    Oct 21, 2020 9:34:56 PM com.rapidminer.extension.nd4j.environment.BackendSwitcher switchBackend
    INFO: Switching backend: BackendSwitchContext{target=GPU-CUDA, fallbacks=[CPU-OpenBLAS]}
    Oct 21, 2020 9:34:56 PM com.rapidminer.extension.nd4j.environment.BackendSwitcher activateBackend
    INFO: Activating backend: org.nd4j.linalg.jcublas.JCublasBackend
    Oct 21, 2020 9:34:56 PM com.rapidminer.tools.config.ConfigurationManager register
    INFO: Registered configurator SFTP Connection.
    INFO: Registered configurator Aylien Text API (Toolbox).
    INFO: Registered configurator MeaningCloud (Toolbox).
    Oct 21, 2020 9:34:57 PM com.rapidminer.extension.nd4j.tool.ReflectionTool resetNativeOpsHolder
    Oct 21, 2020 9:34:57 PM com.rapidminer.extension.nd4j.environment.EnvironmentHandlerImpl switchBackendAsync
    INFO: Switching backend to: GPU-CUDA
    Oct 21, 2020 9:34:57 PM com.rapidminer.repository.RepositoryManager registerExtensionSamples
    INFO: Registered 'Time Series' as sample folder.
    Oct 21, 2020 9:34:57 PM com.rapidminer.extension.deeplearning.PluginInitDeepLearning initPlugin
    INFO: Loading Deep Learning libraries and adding them to ND4J's loader
    Oct 21, 2020 9:34:57 PM com.rapidminer.extension.nd4j.tool.JarTool unzipAndLoadLibs
    INFO: Start unzipping and loading libraries: JarContext{archive=java.util.jar.JarFile@7a45d714, pluginId='rmx_deeplearning', artifacts=[dl-libs-1.0.0-all.jar, dl-linux-libs-1.0.0-all.jar]}
    Oct 21, 2020 9:34:57 PM com.rapidminer.extension.nd4j.tool.ReflectionTool extendClassloader
    INFO: Extending classloader with: [/home/jacob/.RapidMiner/managed/workspace/rmx_deeplearning/dl-libs-1.0.0-all.jar, /home/jacob/.RapidMiner/managed/workspace/rmx_deeplearning/dl-linux-libs-1.0.0-all.jar]
    INFO: Lib file on class path: /home/jacob/.RapidMiner/managed/workspace/rmx_deeplearning/dl-libs-1.0.0-all.jar
    INFO: Lib file on class path: /home/jacob/.RapidMiner/managed/workspace/rmx_deeplearning/dl-linux-libs-1.0.0-all.jar
    Oct 21, 2020 9:34:58 PM com.rapidminer.tools.plugin.Plugin initAll
    INFO: Extension Shapelet was loaded in 4ms.
    INFO: Extension Feature-Selection-Extension was loaded in 5ms.
    INFO: Extension Wordnet was loaded in 5ms.
    INFO: Extension Converters was loaded in 6ms.
    INFO: Extension Anomaly Detection was loaded in 10ms.
    INFO: Extension Smile was loaded in 11ms.
    INFO: Extension Text Processing was loaded in 25ms.
    INFO: Extension Operator Toolbox was loaded in 83ms.
    INFO: Extension Statistics Extension was loaded in 101ms.
    INFO: Extension Word2Vec was loaded in 103ms.
    INFO: Extension Utility was loaded in 117ms.
    INFO: Extension Blending was loaded in 118ms.
    INFO: Extension Concurrency was loaded in 121ms.
    INFO: Extension Professional was loaded in 123ms.
    INFO: Extension Operator Recommender was loaded in 126ms.
    INFO: Extension Legacy Result Access was loaded in 129ms.
    INFO: Extension Python Scripting was loaded in 132ms.
    INFO: Extension Productivity was loaded in 133ms.
    INFO: Extension Social Media was loaded in 139ms.
    INFO: Extension Custom Operators was loaded in 142ms.
    INFO: Extension Model Deployment Management was loaded in 145ms.
    INFO: Extension Advanced File Connectors was loaded in 148ms.
    INFO: Extension Remote Repository was loaded in 163ms.
    INFO: Extension Model Simulator was loaded in 166ms.
    INFO: Extension Data Editor was loaded in 167ms.
    INFO: Extension CTA was loaded in 170ms.
    INFO: Extension Time Series was loaded in 176ms.
    INFO: Extension HTML5 Charts was loaded in 197ms.
    INFO: Extension Browser was loaded in 210ms.
    INFO: Extension Deep Learning was loaded in 288ms.
    INFO: Extension Process Scheduling was loaded in 369ms.
    INFO: Extension Web Mining was loaded in 442ms.
    INFO: Extension JDBC Connectors was loaded in 602ms.
    INFO: Extension Cloud Connectivity was loaded in 654ms.
    INFO: Extension H2O was loaded in 750ms.
    INFO: Extension ND4J was loaded in 4483ms.
    Oct 21, 2020 9:34:58 PM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
    INFO: Global Search category operator registered.
    Oct 21, 2020 9:35:08 PM com.rapidminer.operator.ports.metadata.MDTransformer transformMetaData
    WARNING: Error during meta data transformation: java.lang.NullPointerException
    at com.rapidminer.extension.operator.blending.ExtractAggregatesAdvanced$1.transformMD(ExtractAggregatesAdvanced.java:64)
    at com.rapidminer.operator.ports.metadata.MDTransformer.transformMetaData(MDTransformer.java:59)
    at com.rapidminer.operator.Operator.transformMetaData(Operator.java:2261)
    at com.rapidminer.gui.processeditor.search.OperatorGlobalSearchManager.createOutputPortField(OperatorGlobalSearchManager.java:242)
    at com.rapidminer.gui.processeditor.search.OperatorGlobalSearchManager.createDocument(OperatorGlobalSearchManager.java:156)
    at com.rapidminer.gui.processeditor.search.OperatorGlobalSearchManager.operatorRegistered(OperatorGlobalSearchManager.java:101)
    at com.rapidminer.tools.OperatorService.invokeOperatorRegisteredListener(OperatorService.java:937)
    at com.rapidminer.tools.OperatorService.registerOperator(OperatorService.java:605)
    at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:435)
    at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:424)
    at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:398)
    at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:345)
    at com.rapidminer.tools.plugin.Plugin.registerOperators(Plugin.java:696)
    at com.rapidminer.tools.plugin.Plugin.registerAllPluginOperators(Plugin.java:1267)
    at com.rapidminer.tools.OperatorService.init(OperatorService.java:222)
    at com.rapidminer.RapidMiner.init(RapidMiner.java:782)
    at com.rapidminer.RapidMiner.init(RapidMiner.java:689)
    at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:430)
    at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:1026)
    at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:957)
    at com.rapidminer.launcher.GUILauncher.main(GUILauncher.java:330)
    Oct 21, 2020 9:35:08 PM com.rapidminer.operator.ports.metadata.MetaData addAdditionalData
    WARNING: Additional arbitrary data for meta data is deprecated and should be avoided. Use Annotations instead.
    at com.rapidminer.extension.operator.utility.SetMetaData.lambda$new$0(SetMetaData.java:61)
    at com.rapidminer.tools.OperatorService.registerOperator(OperatorService.java:600)
    Oct 21, 2020 9:35:08 PM com.rapidminer.extension.operator.blending.TsneOperator$1 modifyExampleSet
    WARNING: PCA number of fixed result components was set to 2. Operator can only reduce to 0
    Oct 21, 2020 9:35:08 PM com.rapidminer.tools.OperatorService parseOperators
    WARNING: Cannot create operator description: rmx_smile : smile_random_forest
    java.lang.ClassNotFoundException: com.rapidminer.extension.operator.regression.RandomForestOperator
    at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
    at com.rapidminer.tools.plugin.PluginClassLoader.loadClass(PluginClassLoader.java:131)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
    at java.lang.Class.forName0(Native Method)
    at java.lang.Class.forName(Class.java:348)
    at com.rapidminer.operator.OperatorDescription.<init>(OperatorDescription.java:132)
    at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:432)
    Oct 21, 2020 9:35:09 PM com.rapidminer.operator.ports.metadata.MetaData addAdditionalData
    Oct 21, 2020 9:35:09 PM com.rapidminer.operator.ports.metadata.MetaData getAdditionalData
    Oct 21, 2020 9:35:09 PM com.rapidminer.tools.config.ClientConfigurationManager loadAllParameters
    INFO: No configuration file found for Aylien Text API (Toolbox)
    INFO: No configuration file found for MeaningCloud (Toolbox)
    INFO: No configuration file found for SFTP Connection
    INFO: No configuration file found for Amazon S3 Connection
    INFO: No configuration file found for Azure Blob Storage Connection
    INFO: No configuration file found for Azure Data Lake Storage Gen1 Connection
    INFO: No configuration file found for gui.configurable.cloud.azure.gen2.name
    INFO: No configuration file found for Dropbox Connection
    INFO: No configuration file found for Salesforce Connection
    INFO: No configuration file found for Google Cloud Storage Connection
    INFO: No configuration file found for Twitter Connection
    Oct 21, 2020 9:35:09 PM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
    INFO: Global Search category actions registered.
    Oct 21, 2020 9:35:10 PM com.rapidminer.extension.browser.PluginInitBrowser lambda$initGui$5
    INFO: Async: Hardware accelerated browser setup test starting.
    INFO: Async: Created hardware accelerated browser instance.
    INFO: Async: Loaded hardware accelerated browser test content. Executing functionality check.
    INFO: Async: Hardware accelerated browser setup test successful.
    Oct 21, 2020 9:35:11 PM com.rapidminer.extension.nd4j.PluginInitND4J initGui
    INFO: Waiting for environment initialization to finish
    Oct 21, 2020 9:35:11 PM com.rapidminer.repository.RepositoryManager registerExtensionSamples
    INFO: Registered 'Deep Learning' as sample folder.
    Oct 21, 2020 9:35:12 PM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
    INFO: Global Search category academy registered.
    Oct 21, 2020 9:35:12 PM com.rapidminer.gui.search.GlobalSearchGUIRegistry registerSearchVisualizationProvider
    INFO: Global Search GUI provider added for category academy.
    INFO: Global Search GUI provider added for category operator.
    INFO: Global Search GUI provider added for category repository.
    INFO: Global Search GUI provider added for category actions.
    INFO: Global Search category marketplace registered.
    INFO: Global Search GUI provider added for category marketplace.
    Oct 21, 2020 9:35:14 PM com.rapidminer.extension.remote.PluginInitRemoteRepository$1 run
    INFO: Community repository 'Training Resources' added.
    INFO: Community repository 'Community Samples' added.
    Oct 21, 2020 9:35:19 PM com.rapidminer.io.process.XMLImporter addMessage
    INFO: Operator 'Process' was created with version '9.4.000'. The operator's behaviour has changed as of version '9.8.000' and can be adapted to the latest version in the parameter panel.
    Oct 21, 2020 9:35:24 PM com.rapidminer.tools.ResultService init
    INFO: No filename given for result file, using stdout for logging results!
    Oct 21, 2020 9:35:24 PM com.rapidminer.Process execute
    INFO: Process //Dropbox Repository/Deep Learning/RM Examples/02 Regression of sea shell ages starts
    Oct 21, 2020 9:35:24 PM com.rapidminer.tools.WrapperLoggingHandler logWarning
    Oct 21, 2020 9:35:24 PM com.rapidminer.gui.ProcessThread run
    java.lang.UnsupportedOperationException: The method getNominalMapping() is not supported by numerical attributes! You probably tried to execute an operator on a numerical data which is only able to handle nominal values. You could use one of the discretization operators before this application.
    at com.rapidminer.example.table.NumericalAttribute.getMapping(NumericalAttribute.java:90)
    at com.rapidminer.extension.deeplearning.operators.SequentialNetwork.prepareTestInput(SequentialNetwork.java:223)
    at com.rapidminer.extension.deeplearning.operators.SequentialNetwork.prepareInput(SequentialNetwork.java:183)
    at com.rapidminer.extension.deeplearning.operators.AbstractSequentialNetworkOperator.doWork(AbstractSequentialNetworkOperator.java:243)
    at com.rapidminer.operator.Operator.execute(Operator.java:1022)
    at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
    at com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:806)
    at com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:801)
    at java.security.AccessController.doPrivileged(Native Method)
    at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:801)
    at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
    at com.rapidminer.Process.executeRoot(Process.java:1464)
    at com.rapidminer.Process.lambda$executeRootInPool$5(Process.java:1443)
    at com.rapidminer.studio.concurrency.internal.AbstractConcurrencyContext$AdaptedCallable.exec(AbstractConcurrencyContext.java:362)
    at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)
    at java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)
    at java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)
    at java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:157)
    Oct 21, 2020 9:35:24 PM com.rapidminer.gui.ProcessThread logProcessTreeList
    SEVERE: Here:
    SEVERE:           Process[1] (Process)
    SEVERE:            subprocess 'Main Process'
    SEVERE:              +- Retrieve Abalone[1] (Retrieve)
    SEVERE:              +- Set Role[1] (Set Role)
    SEVERE:              +- Nominal to Numerical[1] (Nominal to Numerical)
    SEVERE:              +- Split Data[1] (Split Data)
    SEVERE:        ==>   +- Deep Learning[1] (Deep Learning)
    SEVERE:            subprocess 'Layer Architecture'
    SEVERE:              |     +- Add Fully-Connected Layer[0] (Add Fully-Connected Layer)
    SEVERE:              |     +- Add Fully-Connected Layer (2)[0] (Add Fully-Connected Layer)
    SEVERE:              +- Apply Model[0] (Apply Model)
    SEVERE:              +- Performance[0] (Performance (Regression))
    Oct 21, 2020 9:35:31 PM com.rapidminer.gui.RapidMinerGUI$ShutdownHook run
    INFO: Running shutdown sequence.
    Oct 21, 2020 9:35:33 PM com.rapidminer.extension.cta.tools.CallToActionScheduler shutdown
    INFO: Shutting down CTA scheduler.
    OP
    @pschlunder I wonder if this issue is in any way related to my previous DL extension problem, this one is easily reproduceable though.
    User: "pschlunder"
    Accepted Answer
    this is a bug and will be fixed in the next release, thanks a lot for reporting it!
    OP
    @pschlunder thanks for confirming my hunch!
    User: "pschlunder"
    Hey @jacobcybulski, short update the bug fix is now released. You can know update to Deep Learning extension version 1.0.1, it should be fixed now.
