🎉Community Raffle - Win $25
Join and Win
Contract # in the middle of an Invoice
User: "Nicole Gutierrez"
Altair Community Member
Updated by Nicole Gutierrez
I have a report with a Contract # in the middle of the Invoice. The Detail option is already being used for the billing information. If I use Append to capture the Contract # only half of the results will receive the data the rest is NULL. if I use Header or Footer it is the same issue. How do I capture the Contract# for all line items?
1 - 7 of 71
    User: "Baba_Majekodunmi_703"
    Altair Employee
    Updated by Baba_Majekodunmi_703
    Hi Nicole,
    From what you’ve described I would create a second model and make the contract # the detail template, then I would combine the two models together using data prep studio.
    Does that make sense? Would you like an example?
    If you look at the templates we have in our Monarch App Library for “Invocies” you’ll see some prebuilt templates where we’ve done this.
    OP
    Thanks so much. I will review the pre-built templates as we really only use the classic version of Monarch.
    OP
    Where do I locate the Monarch App Library?
    Altair Employee
    Here it is: Monarch App Library
    OP
    Thank you so much Baba!
    Altair Employee
    By the way, you should also consider getting formally certified in Monarch....
    Monarch Certification
    User: "CPorthouse"
    Altair Employee
    Updated by CPorthouse
    Is it possible to share a sample of the report or a screenshot showing the layout (with any sensitive info redacted)?  Does the contract # appear in the same position relative to the detail?  You may be able to use a multi-line sample.
    Are you using Classic or Data Prep Studio?  If using DPS, another option would be to use the append or footer and then use sorts and ditto's to fill in the missing values.
