ARIMA parameter configuration p, q, d
Barclaeys
Barclaeys New Altair Community Member
edited November 2024 in Community Q&A
hi,
I am fairly new to data science and exploring time-series. I'm currently trying the ARIMA model but notice there is a big difference in the outcome of the model by configuring the p, q and d parameters. Is there anyone who can explain in simple words what each parameter means and how I can come up with the best configuration? Or should I use the default and use a parameter optimization?
I hope someone can share his/her experience.
Thanks,
Bart
Welcome!
Best Answer
Answers
  • Barclaeys
    Martin, once more thanks for your feedback. Is my understanding correct that to determine the best setting for the auto-regression, I should run an ACF on my data and check for how many lags I still see a specific correlation? And If so, is there anything similar that I can run for the MA part?
    Thanks, Bart
  • MartinLiebig
    MartinLiebig
    Altair Employee
    i think there are in general two schools of thought here, when it comes down to hyper parameter settings
    The Statisticians Way: Analyze the data and check what the right parameters of the algorithms should be. For example with ACF, but also other methods. For ARIMA I am not sure if there is a standard test to figure it out. @David_A and @yyhuang are bigger experts on this topic.
    The Data Scientists Way: Just try many p/q/d values and find the best ones by doing a proper out-of-sample test.
    I am a fan of #2, but this does not mean that #1 is wrong.
    Best,
    Martin
Welcome!
Welcome!
