Holt-Winters predicts over a 30days period as opposed to months
hi, I have just built a Holt-Winters model with Apply forecast on monthly aggregated data. My month is of Type "Date" and is shown as Sep 1, 2015 / Oct 1, 2015 / Nov 1, 2015...
When I look at the prediction, the result set does not predict for Jun 1, 2020 / Jul 1, 2020 / Aug 1, 2020 but takes Jun 1, 2020 / Jul 30, 2020 / Aug 29 2020 / Sep 28 2020 so it seams to keep a fixed 30 days rather than doing the forecast for the 1st of the month.
Is this normal and is there any way I can change this?
Thank you!
Thank you!
1 - 4 of
41
Hi @Barclaeys ,
it somewhat is. Those methods assume, that your data is equidistant. Sadly months (and years) are not equidistant. So what the algorithm takes is i think the average of the steps, since we prefer to give you a solution over an error.
I think @tftemme and team is working on finding a nice solution for those "calendar types". For now there is not a real solution, other than using a generic ID, like I do in my Auto-Forecasting project: https://community.rapidminer.com/discussion/comment/66543#Comment_66543
Alternativly one can think about a postprocessing to adjust the date to the next 1st of the Month.
Best,
Martin
Hi @Barclaeys ,
sure! Attached is an example doing it. This works until you forecast more than 15 months, which is i think kind of rare.
Best,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.7.002" expanded="true" name="Process">
<parameter key="logverbosity" value="init"/>
<parameter key="random_seed" value="2001"/>
<parameter key="send_mail" value="never"/>
<parameter key="notification_email" value=""/>
<parameter key="process_duration_for_mail" value="30"/>
<parameter key="encoding" value="SYSTEM"/>
<process expanded="true">
<operator activated="true" class="utility:create_exampleset" compatibility="9.7.002" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="136">
<parameter key="generator_type" value="attribute functions"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions">
<parameter key="date" value="date_add(date_parse_custom("01/01/2010","dd/MM/yyyy"),id,DATE_UNIT_MONTH)"/>
<parameter key="value" value="rand()"/>
</list>
<parameter key="add_id_attribute" value="true"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="column_separator" value=","/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
</operator>
<operator activated="true" class="time_series:arima_trainer" compatibility="9.7.000" expanded="true" height="103" name="ARIMA" width="90" x="246" y="136">
<parameter key="time_series_attribute" value="value"/>
<parameter key="has_indices" value="true"/>
<parameter key="indices_attribute" value="date"/>
<parameter key="p:_order_of_the_autoregressive_model" value="1"/>
<parameter key="d:_degree_of_differencing" value="0"/>
<parameter key="q:_order_of_the_moving-average_model" value="1"/>
<parameter key="estimate_constant" value="true"/>
<parameter key="main_criterion" value="aic"/>
</operator>
<operator activated="true" class="time_series:apply_forecast" compatibility="9.7.000" expanded="true" height="82" name="Apply Forecast" width="90" x="380" y="136">
<parameter key="forecast_horizon" value="5"/>
<parameter key="add_original_time_series" value="true"/>
<parameter key="add_combined_time_series" value="true"/>
</operator>
<operator activated="true" class="generate_attributes" compatibility="9.7.002" expanded="true" height="82" name="Generate Attributes" width="90" x="514" y="136">
<parameter key="delta_this_month" value="date_diff( date,date_set(date,1,DATE_UNIT_DAY) )/1000/60/60/24"/>
<parameter key="delta_next_month" value="date_diff( date, date_add( 	date_set( 		date,1,DATE_UNIT_DAY 	), 	1, 	DATE_UNIT_MONTH) 	 )	/1000/60/60/24"/>
<parameter key="adjusted_date" value="if( 	abs(delta_this_month)<abs(delta_next_month), 	date_set(date,1,DATE_UNIT_DAY), 	date_add(date_set(date,1,DATE_UNIT_DAY),1,DATE_UNIT_MONTH) 	)"/>
</list>
<parameter key="keep_all" value="true"/>
</operator>
<connect from_op="Create ExampleSet" from_port="output" to_op="ARIMA" to_port="example set"/>
<connect from_op="ARIMA" from_port="forecast model" to_op="Apply Forecast" to_port="forecast model"/>
<connect from_op="Apply Forecast" from_port="example set" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</operator>
</operator>
</operator>
</list>
</operator>
</process>
</operator>
</process>
1 - 1 of
11
Hi @Barclaeys ,
Best,
Martin
