How can i Improve my kappa and the accuracy?for the predictive model?
Aaadi
Aaadi New Altair Community Member
edited November 2024 in Community Q&A
I'm getting accuracy around 97.8 and kappa around 0.87 i want omake thgis satble what are the operatos should i make changes on?
Answers
  • varunm1
    varunm1 New Altair Community Member
    Hello @Aaadi
    Are you tuning your model hyperparameters? Are you extracting relevant features from your data so that they add value to the model? Did you try different models?. There are multiple things you can look at to improve your model performance. You should also look at the type of validation you are using, are you doing a split validation or cross-validation? If split, then this high performance might be based on random chance. You need to provide more information about the problem you are trying to solve for us to provide appropriate recommendations.
Welcome!
Welcome!
