Tokenization vs N-grams
HeikoeWin786
HeikoeWin786 New Altair Community Member
edited November 2024 in Community Q&A
Hello guys,
I am doing sentiment analysis in Rapidminer. While performing word vector, I find that there is two approach tokenization (by non-letter) and generate n-grams. I am not sure the main difference between this two operator and their best use-cases. Can someone explain me how this two works differently in rapidminer? For sentiment analysis, which approach would you suggest; tokenization or n-grams?
Thanks and regards,
Heikoe
Best Answer
  • kayman
    kayman New Altair Community Member
    Answer ✓
    n-grams are successive tokens (or words in this case), so they are related. Using n-grams never hurts an NLP workflow so just use them if your workflow can handle it. In this case you have both your single tokens (words) and the n-grams that can be used for your training.
     Bi-grams will do fine for sentiment, anything more isn't typically give much added value.
Answers
  • kayman
    Answer ✓
  • HeikoeWin786
    @kayman
    Thanks for your clarification here.
    Meaning to say that, we use Bi-grams as a part of data pre-processing.
    i.e. inside the process document to data operator, we put b-grams as a part of data pre-processing together with the tokenize, stem porter and etc?
    Thanks and regards,
    Heikoe
Welcome!
Welcome!
