Missing attributes
User: "bernardo_pagnon"
New Altair Community Member
Updated by Jocelyn
Hello,
I am having the classical missing attributes problem. I have three nominal attributes, and I want to turn two into numerical, and one into text. When I use nominal to numerical only the attribute I want to turn in to text shows up. I tried the "synchronize meta data with real data" to no avail: the attributes do appear after I select this option, but then RM converts each entry into a new attribute.
Any help is appreciated.
Best,
Bernardo
1 - 4 of 41
    User: "hbajpai"
    Accepted Answer
    Hey @bernardo_pagnon,
    When you are transposing the data, you are also transposing the cluster column which has nominal values cluster 1 and 2 for the other columns, that is causing the issue. I dropped it and the flow works as expected.
    OP
    Dear Harshit,
    thank you very much for your reply! Your suggestion solved the problem. What upsets me is that I was aware of the problem, and cleaned cluster using filter examples. It did not work.
    Even when I reproduced your solution the attributes would not appear, and I used inverse selection to save the day. There is something weird with RapidMiner regarding the display of attributes.
    Thanks again, and I wish you a great day.
    Bernardo
    Hi,
    if you mouse over the ports you can see the meta data which is transfered. This way you can figure out which operator is forgetting to add the attribute to the meta data.
    Usually this is a read operator, where we have a harder time to know what attributes are in the file.
    Best,
    Martin
    OP
    That is a nice tip, thanks Martin!
