🎉Community Raffle - Win $25
Join and Win
How to mesh a hollowed sphere
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I'm involved to mesh the attached solid model in order to optimize a three dimensional node. It's a hollowed sphere cutted on the top and some random holes. The point is the model doesn't present symmetries. How can I mesh this solid? First of all, at the beginning I find an edge problem showed.
Can someone please lead me in this particular process?
Thanks.
Alberto
1 - 8 of 81
    User: "Pranav Hari"
    Altair Community Member
    Updated by Pranav Hari
    Hi albertolazzeri
    You can remove the free edges in the geometry by the option Geometry > Edge edit > equivalence
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.b701cb010fafad2a7eb46ece14c34aef.png
    Then you can do a Tetra mesh once it has became an enclosed volume.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.4e71bde4f0e55ec090a1512b304b6450.png
    Altair Employee
    OP
    Thank you very much Pranav Hari for your quick answer,  the edge's problem is solved, but the message 'the mesh is not enclosed' continue to appear.
    Can I try to mesh the external surface and extend all the thickness up to the inside edge?  Could this method works?
    Thank you very much
    User: "Pranav Hari"
    Hi albertolazzeri
    Can you please share your model. I will check and try.
    Altair Employee
    OP
    Altair Employee
    OP
    I removed the free edges in the geometry and I meshed the sphere but some holes result full, not more empty. I tried the boolean subtraction with a cylinder to recondition the hole but the program doesn't not allow me to select the sphere.
    Any suggestions?
    <?xml version="1.0" encoding="UTF-8"?>2.thumb.png.8715e826adc9c03b60e01ddcff83d22c.png<?xml version="1.0" encoding="UTF-8"?>1.thumb.png.be3688588b881a6a857a123f0a14793a.png
    User: "Pranav Hari"
    Hi albertolazzeri
    Did you mean you want to make the cylinder hollow on both sides
    User: "Pranav Hari"
    Hi albertolazzeri
    You can use geometry > surface edit > trim with surface to remove the unwanted surface on top of the sphere.
    check this video on how to trim surfaces
    Once you trim surface you can mesh it and clear the free edges.
    Altair Employee
    OP
    Thank you very much for your help.
    Very professional and exhaustive, I made some basic errors in the procedure.
