Hi figs! Are you sure that you're using the correct port and that the inserted schema name is also existing in the database? PostgreSQL's default port is 5432.
I think the root cause is not anything in database handling from Server, it's an isolated DB connection error and probably just configuration (we haven't changed anything related to this ).
