Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
Parts of Speech (POS) Filtering
Hyram
Hi.
I am have tokenised some text and am now trying to remove POS, using the Filter by POS Operator. I have used the following expression: N.*|VB.*|RB.*|JJ.*|MD.*|PP.* in an attempt to keep nouns, adjectives, verbs and adverbs. The problem is that as an example, nouns and verbs were filtered out e.g. the word "need" is no longer present in my text.
What am I doing wrong and do I have the right expression for the POS tokens I want to keep (nouns, adjectives, verbs and adverbs)?
Thanks,
Hyram
AI Studio
Filtering
Accepted answers
Telcontar120
As you seem to know, you need to use the PENN POS tags, which are available here:
https://www.ling.upenn.edu/courses/Fall_2003/ling001/penn_treebank_pos.html
Your expression doesn't look like is has anything obviously wrong with it to me.
@kayman
can you take a look and see if you can find anything wrong?
Also you might try doing one selection at a time to see if there is a problem with the compound expression?
Or try filtering out specific tags rather than keeping only certain tags?
kayman
Hi
@Hyram
@Telcontar120
Seems ok at first glance indeed.
As recommended by Brian try to do the same without filters (or filter one by one) so you get an understanding which tag is given to 'need' by RM. POS tags are sensitive to word location etc, so depending on the string the same word can get different tags.
Need can be both verb or noun for instance, but since you are capturing both it shouldn't be a problem to start with.
You didn't accidentally select the invert option?
All comments
Telcontar120
@kayman
kayman
Hi
@Hyram
@Telcontar120
Hyram
Thank you very much
@Telcontar120
and
@kayman
. I will try what you've suggested. I didn't mistakenly select invert. I've also subsequently found that some of the words reside in the dictionary I'm using for stop words and hence some of them have been filtered out accordingly.
Penelopemax
Having tokenized text, I'm attempting to remove parts of speech (POS) using the Filter by POS Operator. The expression is used to retain nouns, adjectives, verbs, and adverbs. However, I encountered an issue where, for example, the word "need" was filtered out
Seeking a solution to preserve essential words like "need" in the filtered text.
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
