1 - 4 of
41
hi @ElvisAr I believe all you need to do is just enter "dog cat" in the search parameter. I just did this and the results look correct to me:
Scott
Scott
1 - 1 of
11
Scott
Scott
You will probably have to pull in two separate searches and then do your filtering within RapidMiner using other operators (either the text processing operators or simply Filter Examples with compound filter logic).
