🎉Community Raffle - Win $25
Join and Win
Serach Twitter Operator
User: "Hyram"
New Altair Community Member
Updated by Jocelyn
Hi
Instead of searching for a single term/query, I am looking for a list or vector of terms. Can I do this, using one operator or do I need to use x10 operators for searching for 10 terms?
Thanks
1 - 2 of 21
    User: "gmp"
    Accepted Answer
    One way to do this could be to
     - create an Example Set that has all the (10) search terms
     - Use the "Loop examples" operator to extract the search terms and use that in "Search Twitter"
    Here an example:
    <?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="utility:create_exampleset" compatibility="9.6.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="34">
            <parameter key="generator_type" value="comma separated text"/>
            <parameter key="number_of_examples" value="100"/>
            <parameter key="use_stepsize" value="false"/>
            <list key="function_descriptions"/>
            <parameter key="add_id_attribute" value="false"/>
            <list key="numeric_series_configuration"/>
            <list key="date_series_configuration"/>
            <list key="date_series_configuration (interval)"/>
            <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
            <parameter key="time_zone" value="SYSTEM"/>
            <parameter key="input_csv_text" value="query&#10;apples&#10;bananas&#10;@apples&amp;#10;#bananas"/>
            <parameter key="column_separator" value=","/>
            <parameter key="parse_all_as_nominal" value="false"/>
            <parameter key="decimal_point_character" value="."/>
            <parameter key="trim_attribute_names" value="true"/>
          </operator>
          <operator activated="true" class="loop_examples" compatibility="9.6.000" expanded="true" height="103" name="Loop Examples" width="90" x="246" y="34">
            <parameter key="iteration_macro" value="example"/>
              <operator activated="true" class="extract_macro" compatibility="9.6.000" expanded="true" height="68" name="Extract Macro" width="90" x="45" y="34">
                <parameter key="macro" value="query"/>
                <parameter key="macro_type" value="data_value"/>
                <parameter key="statistics" value="average"/>
                <parameter key="attribute_name" value="query"/>
                <parameter key="example_index" value="%{example}"/>
                <list key="additional_macros"/>
              </operator>
              <operator activated="true" class="social_media:search_twitter" compatibility="9.6.000" expanded="true" height="82" name="Search Twitter" width="90" x="179" y="85">
                <parameter key="connection_source" value="repository"/>
                <parameter key="connection_entry" value="//Local Repository/Connections/Twitter"/>
                <parameter key="query" value="%{query}"/>
                <parameter key="result_type" value="recent or popular"/>
                <parameter key="limit" value="5"/>
                <parameter key="filter_by_geo_location" value="false"/>
                <parameter key="radius_unit" value="miles"/>
              </operator>
              <connect from_port="example set" to_op="Extract Macro" to_port="example set"/>
              <connect from_op="Extract Macro" from_port="example set" to_port="example set"/>
              <connect from_op="Search Twitter" from_port="output" to_port="output 1"/>
              <portSpacing port="source_example set" spacing="0"/>
              <portSpacing port="sink_example set" spacing="0"/>
              <portSpacing port="sink_output 1" spacing="0"/>
              <portSpacing port="sink_output 2" spacing="0"/>
            </process>
          </operator>
          <connect from_op="Create ExampleSet" from_port="output" to_op="Loop Examples" to_port="example set"/>
          <connect from_op="Loop Examples" from_port="example set" to_port="result 2"/>
          <connect from_op="Loop Examples" from_port="output 1" to_port="result 1"/>
          <portSpacing port="sink_result 3" spacing="0"/>
        </process>
      </operator>
    </process>
    User: "Hyram"
    OP
    Thank you!
