Rbody Master on Elements Problem
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hi,
I am trying to build a crash model of a bus. As a beginner, I defined all the connections between the parts with RBE2's using Hypermesh with Block110. When I imported the model to Hypercrash, it shows errors on modelchecker for my rigid links: 'Rbody Master on elements'. When I defined the failed rigids again by using 'calculate node' option the is problem fixed, however I have 3700 failed rigids at my model. Are there any easy way to fix this or I should update all 3700 rigids one by one?
Thank you all in advance for the answers.
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited July 2013
    Hi,
    i don't use Hypercrash, but i have found the following description in the Hypercrash help file:
    Error:
    Number of master nodes on structures. Non-free master node of rigid body. A rigid body master node must not be part of an element.
    Correction:
    Open page, Mesh-Editing / Rigid Body / Modify
    It sounds like your error.
    It means you have createt RBodys with the master node on a structural element. Maybe it is not allowed.
    it seems there is no automatic fix up. Please contact the Altair hotline...
    Regards,
    Mario
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited July 2013
    Thank you Mario.
  • tinh
    tinh Altair Community Member
    edited July 2013
    Hi,
    Hi
    to convert RBE style to calculated master node, run this script
    *createmarkpanel elems 1 'select rbe2 elements'
    *createmark elems 2 'by config' rigid rigidlink
    *markintersection elems 1 elems 2
    foreach elemid [set elemlist [hm_getmark elems 1]]  {
    set nodelist [hm_nodelist $elemid]
    eval *createmark nodes 2 $nodelist
    *rigidlinkinodecalandcreate 2 0 0 123456
    eval *createmark elems 1 $elemlist
    *deletemark elems 1
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2016
    Could some have fixed this error message :
    error decomp RBE2           0           3
     error decomp RBE2           0           2
     error decomp RBE2           0           1
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited April 2016
    Could you share the out file of the run?
    Regards
    Rahul R
Welcome!
Welcome!
