Rbody Master on Elements Problem
I am trying to build a crash model of a bus. As a beginner, I defined all the connections between the parts with RBE2's using Hypermesh with Block110. When I imported the model to Hypercrash, it shows errors on modelchecker for my rigid links: 'Rbody Master on elements'. When I defined the failed rigids again by using 'calculate node' option the is problem fixed, however I have 3700 failed rigids at my model. Are there any easy way to fix this or I should update all 3700 rigids one by one?
Thank you all in advance for the answers.
i don't use Hypercrash, but i have found the following description in the Hypercrash help file:
Error:
Number of master nodes on structures. Non-free master node of rigid body. A rigid body master node must not be part of an element.
Correction:
Open page, Mesh-Editing / Rigid Body / Modify
It sounds like your error.
It means you have createt RBodys with the master node on a structural element. Maybe it is not allowed.
it seems there is no automatic fix up. Please contact the Altair hotline...
Mario
0 -
Thank you Mario.
0 -
Altair Forum User said:
Hi
to convert RBE style to calculated master node, run this script
*createmarkpanel elems 1 'select rbe2 elements'
*createmark elems 2 'by config' rigid rigidlink
*markintersection elems 1 elems 2
foreach elemid [set elemlist [hm_getmark elems 1]] {
set nodelist [hm_nodelist $elemid]
eval *createmark nodes 2 $nodelist
*rigidlinkinodecalandcreate 2 0 0 123456
eval *createmark elems 1 $elemlist
*deletemark elems 1
0 -
Could some have fixed this error message :
error decomp RBE2 0 3
error decomp RBE2 0 2
error decomp RBE2 0 10 -
Could you share the out file of the run?
Regards
Rahul R
